AEM fuel pump wont prime!
Old Jun 26, 2015 | 04:31 AM
  #21
s2krayray's Avatar
ikno! I delayed on taking pump out, been busy/tired! plus its suppose to rain for the next week...still want it done asap. ill FB msg you when im ready itll be quicker.
will keep thread updated on what the issue is!
Old Jun 29, 2015 | 11:58 AM
  #22
hvAlfaWant_S2000's Avatar
Originally Posted by s2krayray
I read up some people that have the aero 340+ pumps replace the wires inside the pump to a bigger gauge, think that's necessary?
I thought the same thing when I did the relay on mine. If you look at the stock plug inside the tank here. It seems the wiring inside for the pump is about a 12 gauge (or 10) for the power(blue) and possibly 14 at the ground(skinny black), which still would seem to allow up to 20 amps and that is more than what we need(based on the charts below):
Originally Posted by EngineerX
This wire capacity graphic was not meant for automotive applications, but it'll give you an idea.
Walbro pumps draw about 10A @ 70 psi or ~26psi boost (static fuel pressure of 43.5psi + 26psi boost, more than what most people run)
Special thanks to EngineerX for the charts referenced above. I left my internal plug wiring as is.
Hope it helps!
Old Jul 3, 2015 | 09:57 AM
  #23
TixonPB's Avatar
I was having this same problem intermittently with my AEM320. It finally happened one morning here in my driveway where it wouldn't prime at all. Checked all wires with my multimeter and everything was working as it should with the relay and the power was getting to the pump, it just wouldn't prime at all. I had to get a ride to work and left the car sitting. after work, tried again and the pump primed with no problems at all. Did some research on AEM pumps having the same issue, and decided to replace mine with a Walbro 450lph. Haven't had the issue again and have simply written it off as being a faulty pump. I really need to get around to sending my old one in to AEM to see if I can get money back or something, because I had it in the car less than 6 months before it apparently failed. It seems like we're not alone on this one.
Old Aug 3, 2015 | 04:28 AM
  #24
s2krayray's Avatar
Totally forgot to update, my apologies. The AEM pump ended up failing on me ( tried to jump the pump and nothing )and JJAUTOWERKS was able to warranty it out for me thru AEM. Ended up ordering a Walbro 255 pump and have been great since! AEM sent me a new one and ill be using it as a backup. Thanks all for the help!
Old Aug 3, 2015 | 05:50 AM
  #25
Hershey's Avatar
I have my first aem 320 e85 pump seized up on me and got a replacement one under warranty. The second pump isn't seized up but is already not working. It would still prime if i direct jump it. First pump less than 700 miles. It die as soon as I rewired and went over to e85. My second pump had one day of driving and now it won't prime. I had the pump out to jump start and it did prime. After seeing this post I don't wanna put the second pump back on. I may end up going with a walbro now. Too many horror stories on these pump lately and I don't wanna be stuck somewhere again.
joefish1298
Mar 30, 2021 12:55 AM
benes2k
Jul 15, 2018 05:43 PM
bobbyrandolph440
Jan 19, 2013 08:41 AM
Drkphnx
Sep 27, 2010 02:09 PM
