aem or haltech
Old Oct 1, 2011 | 11:56 AM
Phill24's Avatar
Default aem or haltech
im in the market to buy either a aem emsv2 or haltech im not sure which to buy was looking at the aem for awhile because it has been in my car before and like the way it operates...now i see haltech has a computer thats pnp also i was reading some of the features of the 1 that i like the most is the check engine light control function that allows u to keep ur cel so far from what i see i like both ecus but not sure which would be a better choice...im leaning more towards haltech just for the cel option..what do u guys think?
my setup so far
fbm twinscroll sidewinder
gt35r with 1.06 hotside
2 44mm tail waste gate
fbm 3" down pipe
3" ic pipes
tail 50mm bov
precision 750 ic
id2000
-8 feed -6 return
Pending parts
fbm fuel rail
fbm twin pump hanger
2 fbm340 pumps
fbm headstuds
aem ems v2 or haltech platinum pro
im trying to make 550-600 i will be using e85/e98
Old Oct 1, 2011 | 01:17 PM
wadzii's Avatar
Banned
its been said 1000 times.. one more wont hurt.
ask your tuner. both will run the car just fine and do everything you could ever want, but if the guy tuning it doesnt know how to use it it's junk.
Old Oct 1, 2011 | 01:28 PM
sarge1's Avatar
I also heard haltech as a PNP harness that will allow it to run in tandum with the factory ecu and retain your obdII port for emmission. I'm not sure if this is true or not. Can anyone confirm?
Old Oct 1, 2011 | 02:03 PM
DFWs2k's Avatar
Not true; haltech is not making a harness. Some other companies are making them, though. They arent working perfectly yet.
Old Oct 3, 2011 | 07:16 AM
InductionPerformance's Avatar
my setup so far
fbm 3" down pipe
3" ic pipes
tail 50mm bov
precision 750 ic
id2000
-8 feed -6 return
Pending parts
fbm fuel rail
2 fbm340 pumps
fbm headstuds
My best suggestion to you is to ask your tuner. If you're going to compare features. I would recommend Haltech as it has a few more features than the AEM and is constantly being updated.
Old Oct 3, 2011 | 07:21 AM
boostedf22c's Avatar
AEM Series2!!!!! We just had mine on the dyno with TONS of features hooked up and working flawlessly.
Just curious, what features does a Haltech have that the Series2 doesn't have?
Old Oct 3, 2011 | 07:58 AM
Angerman's Avatar
Haltech isn't making the harnesses, FullBlown makes one that is OBD-II compliant. I used to have the Haltech PS500 with their harness. I did not get the emissions done while it was on so I can't say for sure if it did the job it was supposed to or not . Haltech just came out for 00-05 years on their Pro-Plug-In...
All in all, a majority of the tuners out there know AEM more than Haltech. At least in my area....
Like said, check with tuner. I vote AEM though.
Why not get the Kpro?
The Haltech PS500 has "most" of the capabilities as the v1 has; and the PS1000 has "most" of the capabilities as the v2 has. So I have been told...
Old Oct 4, 2011 | 09:01 AM
I tune a lot of Series 2 cars. I like the Series 2. So this is an unbiased opinion.
Mainly engine protection features. Coolant temperature, oil pressure, coolant pressure, air temperature, exhaust gas temperature and the biggest one fuel pressure. You're able to do fuel enrichment, ignition retard, boost correction and/or a rev limiter based on all these with a definable minimum time. There are also features I as a tuner like that don't affect you.
Old Oct 4, 2011 | 11:52 AM
Phill24's Avatar
SO as a tuner ud say the haltech is better?.....i spoke to my tuner on sunday he doesnt know much about the haltech but seems very interested in it.....i also know another tuner that has tuned on both aem and haltech and hes saying haltech is a better choice....just wanted to see what every1 else on here thought of the ecu
Old Oct 4, 2011 | 07:22 PM
sohc_mshue's Avatar
Either one is a good choice.
ArchAngel2K
Nov 11, 2009 08:36 PM
Kyushin
Aug 14, 2009 10:07 AM
scutrCR
May 24, 2009 04:32 PM
dsddcd
Mar 14, 2009 12:29 PM
