Aem meth kit install time
Old Jun 13, 2016 | 11:08 PM
  #51
markforrester99's Avatar
Originally Posted by s2k manic
I welded a bung on the charge pipe to keep things sealed and the stock res holds a gallon with the pump under it there is gravity helping feed the pump and my charge line is 5 feet long. i have run 100% meth in the tank with no ill effect due to the res being out of the engine bay. As long as the fender liner is in good shape and you use good lines you wont be messing with the pump. If you loose prime you can take the jet apart hit the purge button to clear the air then reassemble. I use an a/c o ring to seal the jet to the bung so i don't destroy the plastic washer
Sounds like good advice. I have noticed that the check valve on my kit seems to leak abit but im not overly concerned as I will be fitting a solenoid to my kit to make sure its safe.
kerm1t
Dec 21, 2012 09:49 AM
Jeremy Clarkson
Sep 11, 2012 11:27 AM
robodeath
Jun 19, 2007 10:35 AM
S2000rentacar
Oct 29, 2005 10:51 AM
silverstone2003
May 9, 2003 12:22 PM
