aem? not starting hot? found another answer
Old Nov 30, 2007 | 01:54 AM
fltsfshr's Avatar
Default aem? not starting hot? found another answer
I haven't had starting issues when hot for a long time until the other day.
Wouldn't start until it cooled off.
We went through everything and it looked right except for one thing.
Voltage was down just a hair on the battery. Enough so that when warm the car wouldn't fire.
Battery replacement solved it.
fltsfshr
Old Dec 7, 2007 | 12:44 PM
fflatulip's Avatar
oh shit, i had the same problem, aem 1012 not starting hot right after i changed my battery
so could it be the aftermarket battery that i put in has a different voltage than before that causing the not staring hot problem ??
what do you think my friend?
Old Dec 7, 2007 | 01:48 PM
fflatulip's Avatar
BTW, do you happened to know the correct voltage or is there somewhere in EMS that could set the voltage tho?
Old Dec 7, 2007 | 02:12 PM
TRBOKEV's Avatar
Yeah the battery could be the problem.
Some of those smaller batteries don't have good CCA like the larger ones do.
Old Dec 7, 2007 | 03:14 PM
stena's Avatar
the battery is probably the problem..the EMS doesnt like weak ones...I didnt have that problem and i think i dont have problem starting the car with the EMS but i had a problem in the morning when its cold like now if i leave the car out,not in the garage the cars bettery is too weak in the morning to start the car and if i put the car in the garage the car starts no problem,and now - few hours ago i solved the starting problem with an oversized REDTOP install.
i think its a 800 cca one..i will put a pic of it later.
Old Dec 7, 2007 | 05:24 PM
fflatulip's Avatar
the new one i put in supposed to be good tho, it's the allstate brand, and they said it's good
will a t1r voltage stabilizer help??
Old Dec 8, 2007 | 07:20 AM
TRBOKEV's Avatar
T1R voltage stabilizer...LOL Yeah mount it inline between the flux capacitor and the battery.
Charper732
Jul 6, 2017 01:29 PM
gettin it
Jan 14, 2013 08:12 AM
ROFLv8
Dec 4, 2012 06:38 PM
AWWHITE s2k
Nov 18, 2012 11:26 AM
ChefJ
May 14, 2008 09:51 PM
