AEM uego install
Old Oct 23, 2012 | 09:58 PM
profit_child's Avatar
Default AEM uego install
okay so today i installed a berk header and CT supercharger kit stock kit 6 psi
im kind of stumped on the wideband install i bout it from a member on here that said you have to splice into the ecu harness o2 wire? for the install? good new i installed the o2 onto my berk header and ran the wire threw the engine bay into the cabin to the gauge itself... now its powering it up and grounding it out? is there anything else i need to do i really need to splice my harness or stock o2 or is this a complete stand alone gauge just o2 sensor power and ground? someone please help me walk threw this thanks!
Old Oct 23, 2012 | 10:24 PM
Reapur's Avatar
Have you read through the install instructions? Tried google?
i mean there are several threads on how to install it specifically in the s2000. I know this because this is how I figured out how to install it.
Old Oct 24, 2012 | 06:22 AM
herecomesboost's Avatar
What model year is your car? For a gauge type UEGO, you only need to wire it into the ECU if you're planning to use the AF as feedback for the ECU itself. Otherwise, you can simply leave those wire disconnected. Are you still using your stock O2 sensor? Which EMS?
Old Oct 25, 2012 | 08:28 AM
currently on on vafc2 on comptech ecm module and comptech stock kit... no i dont need any feedback for the ecu... i just want the proper running gauge for tunning purposes.. and for me to keep my eye on it... so all i need is power ground and run the o2 sensor? no need to splice the oem sensor or anything correct?
didnt come with instructions.. bout it used... i searched on here for the install DIY no results.
Old Oct 25, 2012 | 09:09 AM
Reapur's Avatar
Google. The install instructions are on AEMs website as a PDF download.
Search google for s2000 AEM uego Wideband install
FlyinRyan02S
Jan 17, 2014 06:05 AM
Wakeupfranky
Mar 6, 2013 11:00 AM
djpeak10
Nov 17, 2006 02:37 PM
macspeed704
Nov 9, 2005 04:01 PM
CRX 18
Sep 16, 2003 11:43 AM
