AEM UEGO questions
Old Aug 17, 2007 | 07:46 PM
Avernus's Avatar
Default AEM UEGO questions
So there are 2 types of AEM EMS's:
you got the regular and the UEGO wideband.
What is the actual difference, and if it's not obvious what are the Pros/cons to the UEGO?
I tried searching but I came up with nothing.
P.S. Where would the cheapest and most trusted place/site for getting them be?
Thanks
Old Aug 18, 2007 | 03:54 AM
s0rted's Avatar
The regular version is just the ecu. The EMS with UEGO incorporates a wideband oxygen sensor which you plug into the exhaust.
Old Aug 18, 2007 | 03:06 PM
Avernus's Avatar
would that be a 'definitly need it part' for a turbo setup(inline)?
Old Aug 18, 2007 | 03:11 PM
hokies2000's Avatar
It's not absolutely necessary. But, it is my understand the UEGO is the only thing that can make any kind of minor adjustments depending on what it is reading. The EMS doesn't learn or adjust.
Old Aug 19, 2007 | 02:29 AM
s0rted's Avatar
That is incorrect. The EMS, with or without UEGO can and will make adjustments based on a large number of scalable tables IF it is programmed to do so. What I'm trying to say it can react to changes in preetty much every sensor that's hooked up to it.
The UEGO option is simply a wideband oxygen sensor - useful for tuning and for knowing your AFR's. It does the same job your tuner's 'O2 sniffer' does, only it's hardwired in. The UEGO is more expensive, but it would pretty much work out the same if you were to buy a wideband O2 controller separately.
Old Aug 19, 2007 | 02:41 AM
hokies2000's Avatar
Yes, it scales but it scales on numbers you provide. It doesn't continually adjust the scales (i.e. it has no ability to learn). It's an open loop controller without the UEGO option. The UEGO option runs Closed Loop and can make corrections to maintain a target A/F ratio.
Old Aug 19, 2007 | 07:48 AM
Avernus's Avatar
Now that seems crucial! So for trying to make a turbo more reliable this seems like a must-?
rio04s2k
Jul 17, 2010 10:06 AM
JsRacingS2K
May 16, 2009 06:39 PM
518135
Jan 25, 2009 01:21 PM
Spec_Ops2087
Aug 26, 2007 09:41 PM
regmilla
Oct 6, 2005 05:47 PM
