aftercooler fluid
Originally Posted by SC-S2000,Jan 23 2006, 07:14 PM
but in most cases the coolant could end up cloging quicker over time from residue build ups but that is just my opinion.
The whole idea behind "water wetter" is that it has a more efficient heat transfer mechanism, but in the A/C system, we're not dealing the kinds of heat an engine cooling system is subjected to. Water wetter has some system lubricators and some anti-corrosion elements in it but not nearly as much as anti-freeze, which is designed to be use for this purpose.
Originally Posted by ayS,Jan 24 2006, 01:05 PM
since we are on the topic of aftercooler already, is it 50/50 we put into the aftercooler for coolant/water? or all coolant and no water?
Personally, a 50/50 mix of antifreeze is just too easy, so why not?
Originally Posted by ayS,Jan 25 2006, 11:55 AM
seems my supercharger aftercooler is sucking alot of coolant/water.
Are you saying that you find that you are constantly adding more fluid? How long has the supercharge kit been on? You need to provide more details when you ask a question.
Originally Posted by ayS,Jan 25 2006, 02:00 PM
the supercharger has been on approximately 2 months now. vtec maybe 2-3 times sometimes 4.
and yes, i have been adding fluid lately. but not that much once i had found out that it was low/ or no water of any kind in the aftercooler.
Any new cooling system will take 2 to 3 driving cycles to completely burp out all the air. If you have topped it off 2 to 3 times now and it still requires more fluid, then you have a small leak someplace.
