Aftercooler pump
Old May 3, 2009 | 04:33 PM
9000revolutions's Avatar
Thumbs up Aftercooler pump
I recently bought a used CTSC w/AC. I have everything installed. Where does the aftercooler pumps wire connect to in the cab of the car? Tried a search and only found a install manuel for assembly with out AC. Thanks in advance.
Old May 3, 2009 | 04:45 PM
nightcrawler7188's Avatar
ignition fuse
Old May 3, 2009 | 04:58 PM
do you have a pic of the wire i need to tap
Old May 3, 2009 | 05:03 PM
you just have to run the red wire in to the cabin and attach it to the ignition fuse. not gonna be around my car until tomorrow, won't be able to get a pic. go in the owner's manual or shop manual and find out which one is the ignition. it's on the fuse panel below the steering wheel
Old May 3, 2009 | 05:06 PM
bagherra's Avatar
I put mine in the open accessory area in the driver's side footwell fusebox. If you open up the fuse panel by the driver's side footwell and look at the fusebox you'll see three open slots that would take a flat connector. You can plug it in one of these (add flat connector to your wire).
Hope this helps.
Old May 3, 2009 | 05:58 PM
dans2k's Avatar
Hope this helps.
+1
Old May 4, 2009 | 01:34 PM
BondoBuilder's Avatar
+2 I think that's what Comptech suggests.
Old May 4, 2009 | 02:26 PM
Hope this helps.
Done. Thanks again everyone
Ap2low
Jan 15, 2015 05:10 PM
eastonh477
Oct 28, 2012 04:07 AM
geared
Aug 25, 2012 05:49 PM
Blurter
May 23, 2005 01:38 AM
Fiend
May 23, 2001 06:38 PM
