Hella Airhorn Compressor has two terminals, which one do I use?
My Hella airhorn compressor has a positive and negative terminal. I'm using the relay which has a connection grounding it to the car. Which terminal on the compressor am I supposed to hook the wire running from the relay to, the positive or negative?
Yes the relay has 4 terminals, 2 for the "coil" and 2 for the "contacts" (switch). One contact terminal goes to a 12 volt source (fuse box), the other contact terminal goes to the + terminal of the compressor. One of the coid terminals goes to ground, the other to the "trigger" that is to make the horns blow. The easiest "trigger" to use is the hot lead from the existing horn. This actually puts 2 relays in the circuit (the cars existing horn relay and your new one) and creates a slight time delay but it's not a big deal.
BTW the coil leads carry little current and can be small wire, the contact wires need to be larger gauge.
Lttakas
Jun 29, 2014 09:08 AM
Gracias amigo!
