Aftermarket control arm bushings
I've got my rear, axles, and knuckles removed for an InlinePro 300ZX rear conversion kit............ so, getting the control arms out is a snap at the moment. Are aftermarket control arm bushings of much value? I plan on 6-8 track days, the rest will be moderately aggressive street driving.
Is the answer to the above is 'yes', what/whose bushings do you recommend?
thanks,
Kleecker
thanks,
Kleecker
I haven't investigated which brands fit the S2000, but I have replaced the bushings on several other cars.
Getting the old ones out can be a CHORE, I've always had to burn them out, but getting the new ones in is easy. They are usually 2 piece bushings and just slip back in.
I would add grease Zerks so that you can lube them periodically since the poly bushings will squeak.
