Air Pump with ems
So iv read a ton of posts on this subject.
All that needs to be done is remove the pump and lines. Close up the check valve with a block off plate, and vacuum line going into the intake.
Then for the other hose going into the intake. Just remove it and close up that hole as well?
What about the 3 female plugs that clip into the air pump I just ignore them now?
and last the check valves small vacuume line goes to this
so what happens with this? in the picture ^^and disregard the electric plug that goes in it?
and then theres also the canister thats connected to the previous picture. This goes away as well?
