AIT Temperature increase during WOT
Old Aug 3, 2016 | 07:44 PM
  #31
RAIN H8R's Avatar
I think I have one of those T1 sensors. Id sell it if you are interested...
Old Aug 3, 2016 | 07:55 PM
  #32
rtboy10's Avatar
I've got the AEM sensor and I will say it's pretty bulkly. I plan on trying to mount it on the after cooler outlet before the TB.
I will update after its installed
Old Aug 4, 2016 | 06:07 AM
  #33
EOE's Avatar
EOE
I am still using my OEM sensor so it'll be the same. If you can eliminate your emissions air pump by disconnecting it and installing an emulator module, then yes, you can use that opening instead of drilling. I wish I did that.
Originally Posted by E4RTH WORM JIM
EOE & Rain H8R.
So I suppose the next question is does the 06-09 AIT have the same table values as the 00-05 cars?
If not, what are they so I can install one in the air port on my CT AC? Seems simpler to use that spare port than drilling/tapping or welding a boss onto the AC so a MY00-05 sensor can be used.
Old Aug 4, 2016 | 06:33 AM
  #34
E4RTH WORM JIM's Avatar
Originally Posted by E4RTH WORM JIM' timestamp='1470091430' post='24030093
EOE & Rain H8R.
Yes I have removed the air pump so I'm just going to get a new sensor that will fit in that port. The OEM sensor on my MY00 wouldn't be the neatest of installs. Also I've read on here the AEM cal tables are wrong for the OEM AIT sensor and the temps aren't accurate so it would be nice to get a new more accurate reading...
Old Aug 4, 2016 | 08:46 AM
  #35
I'll drop you a PM when I know exactly what I'm doing
Old Aug 4, 2016 | 11:48 AM
  #36
NWDyno's Avatar
/\ What FI you running?
And do you have the voltage temperature tables for this sensor?
Also, what connection did you specify out of interest?
I'd like to install one of these into my spare aftercooler port using a grommet as per the CT manual quoted above, or if not a weld-on boss.
Or if not the T1 and AEM as below:
http://aemelectronics.com/files/inst...sor%20Data.pdf
I am running Motec m130 and the whole harness is custom so I bought the crimp on connection of course.
Old Aug 5, 2016 | 04:47 AM
  #37
staylor725's Avatar
Originally Posted by NWDyno
This is what I am using for my 2 iat sensors with great success, very responsive!
http://www.t1racedevelopment.com/cat...mp-sensor.html
I have a T1 sensor but its not installed yet what's the best location to install it? I've seen it in the cold side piping near the intercooler behind the bumper and right before the throttle body not sure what is the best location.
Old Aug 5, 2016 | 08:41 AM
  #38
NWDyno's Avatar
I am running two: one before the air/water intercooler and right before the throttle body.
Old Aug 5, 2016 | 09:50 AM
  #39
Very interesting... What temperature differential do you see and what FI kits is it?
Old Aug 5, 2016 | 10:34 AM
  #40
NWDyno's Avatar
Its a turbocharged car. The temp differential all depends on what temperature of water I put in the water container. Sometimes I run tap water basically if not making a hard/full potential pass
