Another AP1 03 Greddy Dyno
I just got back from the dyno today and was disappointed with the power curve but I knew this was a common with this kit. Just some back ground info::
2003 with 58,ooomiles. One step colder NGK plugs, HKS exhaust, Greddy E-01 boost gauge/controller.
Base map with no tunning at 7.5psi on a Dyno Jet with smoothing set at 5.
Run 1: 3rd gear: 259.85hp @ 189.94tq
Run 2: 3rd gear: 253.02hp @ 173.52tq
Run 3: 3rd gear: 250.09hp @ 179.91tq
Run 4: 4th gear: 241.28hp @ 178.12tq
Tunning starts next FRI so a new sheet will be posted by Sat hopefully
do you have the stock cat? is your hks exhaust the hi power dual? if you answered yes to both questions, you could benefit by allowing your engine to breath better with a larger catback or a test pipe only.
not bad for running off the basemap and a small exhaust system.
i just tuned at Church's on thursday with the same setup, I put down 265 whp and 219 lb/ft tq.
so yeah not bad numbers for you at all, I would get tuned and then see. But I am going with new greddy single and gonna retune and hope for near 300 whp at 10psi. gdluck!
mholland15
Jul 20, 2013 07:14 PM
MrWolf4
Feb 3, 2013 01:11 PM
