Torquing Head Bolts
Right after I got my engine back from Laskey Racing I called Earl (RIP) and had a long discussion with him about torquing the head to the block using ARP studs. His recommendation was to use a lot of Molly lube and torque them to 75 ft-lbs, and for sure, not to exceed 80. This seems to go against everything I have read on the F20C engine, but I trust his advice, so that is what I will be using when I install the engine in the next few weeks. Any of our forum experts care to comment on this?
Originally Posted by Slows2k,Jan 10 2007, 05:41 AM
The AEBS studs torque in the same sequence as OEM bolts, and torque angle setting. Given the several headgasket failures with ARP's being torqued under 100ftlbs I wouldn't do it.
Quite a few months back I had the same conversation with Earl too. He recommended that we torque the studs to 75ft/lbs, however he was not too certain on this as he has never tried them on an F20C.
Shortly after this I contacted the company who sold me the studs and they informed me to look at the install sheet. After I asked them if they've ever taken the time to look at these instructions themselves, they informed me they would call ARP and then call me back.
Approximately 20 minutes later I received a call from the individual who informed me to torque them to 86ft/lbs.
Thats the spec that I went with... we triple stepped it to 86 ft lbs. 35/60/86. Then after 1,000 miles we did it again, just to ensure they did not stretch at all.
