ANOTHER BLOWN TURBO
Old Jun 19, 2014 | 11:25 AM
jpetch05's Avatar
^^^ LMFAO passman. he said a minimum of a -4 feed, and a -12 drain is .750 in inside diameter of hose which is okay, problem being some -12 fittingss can be.500 on the inside of the fitting causing a 33% reduction. So formed tubing drains such as factory style coolant hose drains are ideal.
I am for sure upsizing to a -4 feed, im just pissed that i have to take off my timing chain cover to make it a -12 minimum -____-
Old Jun 19, 2014 | 11:33 AM
1SlowSi's Avatar
Aint no way in hell it requires a -12an return lmao!
Originally Posted by KaNgArOo
Whew...not just precisions.
I wouldnt say all that. You dont see many borg warners failing like precisions do. Maybe its just that more people run precisions? I have had 3 out of 3 precisions fail though lol.
Old Jun 19, 2014 | 12:41 PM
lude92_si's Avatar
What SPS told me,
Specifically, it states that the oil supply line should be the same size i.d. as the port design. In your case, the S200SX uses a 1/4"NPT threaded port, and, as the name would imply, this would indicate a .250" (1/4") inner diameter oil supply, so, if AN line is to be used, you would select a -4AN line assembly, making sure that all adaptor fittings are at least the same inner diameter as the hose.
Also told me a -12an drain
Hmmmmmmm
Old Jun 19, 2014 | 02:19 PM
Suprdave's Avatar
-12AN Oil Drain, lolz...did they feed you that bs so they didn't have to warranty?
Old Jun 19, 2014 | 02:40 PM
lude92_si's Avatar
Now I'm wondering if I should go up to a -4an lol. Sps just told me they are redoing a s300 from a s2000 must be urs j
Old Jun 19, 2014 | 05:35 PM
bobbyrandolph440's Avatar
Where do I get a- 12 drain for my BW ITS S366
Sent from my VS870 4G using Tapatalk 2
Old Jun 19, 2014 | 08:12 PM
jpetch05's Avatar
Yup it would be mine sir
I'm gonna upsize I guess just to do it. Can't hurt. f@#ker is dead now anyhow
Old Jun 19, 2014 | 08:53 PM
spdracerut's Avatar
Where is your oil drain located? If it's below the oil level in the pan, that's an issue regardless of drain size.
Old Jun 20, 2014 | 05:07 PM
jpetch05's Avatar
I said it was on the chain cover
Old Jun 20, 2014 | 05:19 PM
Spoolin's Avatar
A -3 inlet from the pressure sensor or relocation block should be just fine and a -8 drain to the girdle is plenty adequate. I've been running this way for years with no issues on the 3 turbo's I've used.
