ANOTHER BLOWN TURBO
Old Jun 21, 2014 | 05:07 AM
  #21
wy2slow_z's Avatar
I also have had problems with my borg. Currently have a -3 feed and -12 return.
Old Jun 21, 2014 | 05:52 AM
  #22
lude92_si's Avatar
Wow I went with Borg for there reliability got me a bit scared :/
Old Jun 21, 2014 | 07:40 AM
  #23
jpetch05's Avatar
Me too. Hopefully changing these two things will prevent this from happening again
Old Jun 21, 2014 | 09:08 AM
  #24
lude92_si's Avatar
$1600 on a new turbo I want it to last! What setup you going with J? -4an this time?
Old Jun 21, 2014 | 09:53 AM
  #25
wadzii's Avatar
Banned
regardless of oil drain size, if you have a ton of crank case pressure the oil wont drain.
Old Jun 21, 2014 | 10:25 AM
  #26
lude92_si's Avatar
So a vented catch can setup would help with pressure? Just installed one.
Old Jun 21, 2014 | 11:31 AM
  #27
Spoolin's Avatar
Exactly! This is why I prefer the girdle for the drain. Very limited crank case pressure in that area and no way for oil to be standing in the area. Having the valve cover venting to atmosphere with an open to atmosphere catch can will help with crank case pressure also.
Old Jun 21, 2014 | 01:03 PM
  #28
jpetch05's Avatar
Yeah I'm going 4 and -12 on the drain. I also have a vented catch can to atmosphere.
Old Jun 22, 2014 | 07:51 AM
  #29
AKs2dope's Avatar
Originally Posted by Spoolin
A -3 inlet from the pressure sensor or relocation block should be just fine and a -8 drain to the girdle is plenty adequate. I've been running this way for years with no issues on the 3 turbo's I've used.
So you are running -3an feed on Oil reolocation block? I was thinking to do the same, but I haven't really seen anyone done it. most people have done is on the sandwhich plate.
I am thinking to run -4AN FEED on the reloc block, and -10AN Drain on TC. MY manifold is FBM single.
Old Jun 22, 2014 | 08:16 AM
  #30
Phill24's Avatar
mine is coming off the filter relocation block as well
ive seen a few evo guys run a small filter on theyre oil feed has anyone else thought of doing this?
