Another Greddy Upgrade
Originally Posted by Josh_With_The_S2K,Jun 9 2009, 10:45 PM
i hear/read that 10psi is a safe/max the stock internals can do. cant find where i read that though. i know it was here somewhere...
Originally Posted by itlynstalyn,Jun 11 2009, 02:27 PM
Actually, he's using a compressor off a GT28 due to space limitations since his steering wheel is on the wrong side
this one might be a better choice for those of us who drive on the correct side of the road as it includes WG actuator. The one sold there at HSTuning does not come with the bracket and WG actuator.
http://www.atpturbo.com/Merchant2/merchant...tegory_Code=GRT
..... just joking on which side of the road you Commonwealth people drive, it does limit you in the choices of turbos. RHD Subarus also suffer from the same constraints as the turbo is also located on the right side near the firewall
Originally Posted by Revenge,Jun 11 2009, 06:30 PM
Yes most people seem to run 10psi and have no problems but you still need a good tune.
Originally Posted by chad86,Jun 9 2009, 06:42 PM
Yah i have read some other threads kickin around but here is a quick one with some guys with high boost and 3mm HG... I realize they may not be DD and are runnin race gas, but it is being done...
https://www.s2ki.com/forums/index.php?showt...&#entry11764621
I am kinda waiting on a fellow s2ki member to figure out what hes doing with his turbo setup, but I may be taking his gt3076r and swap it into my car.. I am hoping to throw in a IP 3mm HG and either run race gas or a much bigger meth nozzle(s) and maybe try for 18-20 psi depending on if the turbo can handle it on not...
