Another valvetrain related question.
Old Apr 9, 2009 | 03:53 PM
ChefJ's Avatar
Default Another valvetrain related question.
I just purchased ferrea dual springs and retainers. I am curious if I can run .5mm oversized valves without changing piston size.
Second question is considering I went with Ferrea should I get ferrea valves and valve guides or can I go with a BC valve and ferrea guides?
Old Apr 9, 2009 | 04:25 PM
dsddcd's Avatar
Chris and Ya, at Inline have had more experience with all of these parts than anyone else.
Old Apr 9, 2009 | 05:13 PM
ChefJ's Avatar
Chris
Ya
anybody
Old Apr 9, 2009 | 05:28 PM
CourageOO7's Avatar
www.inlinepro.com
Call them. They should be able to help.
Old Apr 9, 2009 | 05:45 PM
Venomous S's Avatar
if I recall correctly, my machine shop had told me that you can run:
.5mm over on the intake
1mm over on the exhaust
without having to change anything else.
Old Apr 10, 2009 | 07:00 AM
ya@inlinepro's Avatar
ChefJ,
If you are on the stock bore size, over size valves "might" hurt overall performance, cause you generally shroud some of the combustion chamber.
I personally would stay standard size, unless going bigger bore from factory bore size.
You can run whatever guides, as long as they are installed properly. Also, getting springs and retainers, make SURE you get the new seat bases for the aftermarket dual valves springs. Most places sell it as an option, but its required on the F20's and K20's. If you don't you can and will break a spring.
Ya
Old Apr 10, 2009 | 06:02 PM
ChefJ's Avatar
^ where could I find the seat bases for Ferreas dual spring setup? I just want to get everything purchased now so I can drop it off at the Machine shop and start my tear down.
Old Apr 10, 2009 | 06:07 PM
Artisan7471's Avatar
Did you buy the set from me?, if so I included the seats.
Old Apr 10, 2009 | 06:11 PM
ChefJ's Avatar
^ The set that someone had posted on here linked to ebay. Yea that was me.
Old Apr 11, 2009 | 08:28 PM
ChefJ's Avatar
dished or flat valves for turbo setuo?? I am reading most go with a dished setup. Will supertech work with the ferrea springs?? Ya shoot me some pricing on this stuff. I would prefer to go through you guys then hp freaks or any other website.
Importedpower
Apr 2, 2012 04:01 AM
jimnasty23
Mar 21, 2011 08:58 PM
RUEHL925
Jul 15, 2010 04:44 AM
conanius
16
Sep 3, 2009 02:09 PM
SoCalAp2
May 7, 2009 07:09 AM
