Any flowbench data on a Portflow head?
PortFlow uses standard size valves on the intake because flow testing revealed absolutely no benefit from a larger intake valve. When this is the case, you are always better off using the smaller valve for its slightly lighter weight.
Question for all you experts... What tuning requirements will be needed for this (stage 3) head?
Background: I was planning on using the Greddy eManage Ultimate, however it seems that it does NOT function on the S, at all. Greddy is working on the issue, but has no estimate for the software/hardware release. So, this new head has been sitting in my basement
If you have larger intake valves with forced induction, aren't you able to cram more air in to the cylinder? I was always under the assumption that even if your flow numbers aren't affected, in boost you'll make more power with larger valves.... Thoughts?
