Anyone changed the TCT
Hi,
I 'think' my TCT might be on the way out, but has anyone changed it who running a CTSC+AC?.
Do you have to remove the mounts or can it be done easier/without removal?
Thanks
Thanks
Didn't need to remove the mounts but you will need to take off the VTEC solenoid and spacer that feeds oil the blower in order to get a good grip on the TCT. It took some doing, but I managed to twist it off.
It's a simple process to just remove the three bolts holding it in and pull it out making sure to catch the piston or else it will hide on the frame somewhere. If you use a retracting bolt you won't have to worry about the piston getting lost. No need to move the vtec solenoid or the supercharger.
By using the bolt you don't need to access the inspection hole or pull the pin.
Ivanaguilar
Jul 27, 2017 10:59 PM
beroznikmal
Jul 18, 2003 06:17 AM
