Anyone running larger Throttle body?
I will keep you updated. Was setuping up a date with Jeff but not sure I am going to make this month due to me winterizing the car. So if it doesn't happen now I won't have results for you until late spring when winter is over and the roads are clear of salt. Feel free to friend me on here so I can keep you update with the info. Thanks.
Mike
Mike
Check out maxbore.com. I heard they do a great job and turn around is very quick as well. Oh ya I'm currently 72mm BDL TB and i hate it. BDL is too stiff so i'm going to install my stock one back after I bore it out.
King Motorsports will do your OE throttle body for $175...same as SOS for less. I had mine done by them.
http://www.kingmotorsports.com/
Brian
Brian
Originally Posted by 05S2k02Si,Nov 17 2009, 05:21 AM
King Motorsports will do your OE throttle body for $175...same as SOS for less. I had mind done by them.
Brian
Brian
Any recommendations on the best 70mm TB to get? I would be putting it on a port matched stock bored intake manny. BDL from the looks of it is high quality, certainly cost enough. Skunk 2? Any recommendations on a reliable unit that performs well? There is an OBX 70mm on ebay for $185, good price it seems for a unit with a one year warrantee, but don’t know anything about OBX.
BDL is good quality and made in the USA just down the street. We have them in stock.
Their quality is top notch. You do need to adjust them initially, but once they are dialed in, you won't want to drive without one.
-Asura
-Asura
-Asura
-Asura
Even on a standard Comptech supercharger, our throttle body gained 12 hp at the wheels in independent customer testing:
http://www.scienceofspeed.com/products/exh..._throttle_body/
The throttle bodies are also now designed with o-ring seals on the shafts for water and boost leaks at the ends of the shaft. It is the ONLY throttle body for the S2000 that has this design.
-- Chris
-- Chris
