Anyone running larger Throttle body?
Originally Posted by 05S2k02Si,Nov 17 2009, 06:21 AM
King Motorsports will do your OE throttle body for $175...same as SOS for less. I had mine done by them.
http://www.kingmotorsports.com/
Brian
Brian
regards,
-- Chris
Originally Posted by Chris@SoS,Nov 25 2009, 06:32 PM
One advantage with our throttle body is that the larger throttle plate has the correct taper cut into the larger throttle plate - a requirement as the plate sits at a slight angle in the closed position. Without this, as we've seen with other's modified throttles, the straight cut plate digs into the aluminum causing an interference when opening and closing.
regards,
-- Chris
regards,
-- Chris
Thanks, Brian
