Anyone try a CC pressure plate
Old Apr 28, 2009 | 09:47 AM
blueap2's Avatar
Default Anyone try a CC pressure plate
Just wondering if anyone has tried this combination? I was planning on changing the pp and disk out for an ACT pp and oem disk. I figure why not try the CC pp with OEM disk, since the pp only has about 3k miles on it. I've also read that a lot of these companies are just using reworked Honda pp...
Please input.....
Old Apr 28, 2009 | 09:48 AM
Spec_Ops2087's Avatar
Correct me if I'm wrong but I was under the impression that the CC PP was lighter then OEM? I think my clutch pedal was stiffer when I had the stock clutch installed.
Old Apr 28, 2009 | 09:51 AM
blueap2's Avatar
I believe you are correct. When I put the CC pp the pedal did feel lighter....
Old Apr 28, 2009 | 09:58 AM
AndyFloyd's Avatar
the reason the ACT works so well is because it has more clamp load, the CC PP im not sure about its clamp load. ACT is a 2600lb pressure plate.
Old Apr 28, 2009 | 06:52 PM
blueap2's Avatar
I spoke to the guys at CC and they said it should be fine. They mentioned their pressure plate has a 2400lb clamp force..
Old Apr 28, 2009 | 07:06 PM
John_Z's Avatar
OEM disk is organic and will turn to mush under high tq conditions.
Old Apr 28, 2009 | 10:27 PM
blueap2's Avatar
what do you consider high tq conditions? i dont plan on making anything over 300 lbs ft
Old Apr 29, 2009 | 06:28 AM
John_Z's Avatar
I would say anything above 300ft lbs is high tq. I personally wouldn't take an oem disk past 275ft lbs just for longevity reasons.
Old Apr 29, 2009 | 08:28 AM
AndyFloyd's Avatar
OEM disk + 370ft/lb= perfect. Cant say I agree with you. I have an ACT organic disk, its the same as OEM they are both organic.
Old Apr 29, 2009 | 03:37 PM
blueap2's Avatar
^^^^^^^^ good to hear.....im gonna bite the bullet and give this a shot.
s2k_996
Jul 18, 2010 06:13 AM
Diddy2K
Jul 2, 2010 02:06 PM
ChefJ
Jan 21, 2009 06:30 PM
h22boy
Apr 30, 2007 07:54 PM
MrChoi
Feb 17, 2006 09:11 AM
