AP1 Fuel Rail Tap Photos?
Old Mar 13, 2019 | 03:16 PM
s2kvince's Avatar
Default AP1 Fuel Rail Tap Photos?
Does anyone have photos of where the AP1 fuel rail should be drilled and tapped for a sensor? I want to confirm I'm drilling into an actual hollow spot. Also, any tips to ensure I get all metal shavings out?
Old Mar 13, 2019 | 05:35 PM
jdmz's Avatar
Use the fuel pulsation damper center-line as a reference. Make sure your gauge doesn't hit that valve cover vent line if its hard and you are good. It doesn't have to be perfect because you don't need a full sized hole as large as your tap to get a pressure reading. Make sure you flush it a bunch of times with carb cleaner or wd40 and shine a light to inspect if there are metal shavings.
Old Mar 13, 2019 | 05:47 PM
yamahaSHO's Avatar
Old Mar 13, 2019 | 05:58 PM
s2kvince's Avatar
Thanks! I'm actually just tapping for a feed line to a firewall mounted pressure transducer, but that looks like it will work
Old Mar 13, 2019 | 07:04 PM
yamahaSHO's Avatar
I will eventually change mine to a sensor to route into my ECU, but for the time being, it is there to set base pressure
Old Mar 14, 2019 | 05:16 PM
jdmz's Avatar
I'm swapping mine out with the clean injection brand transducer. Hopefully it's as reliable as the aem one.
Old Mar 14, 2019 | 07:18 PM
hecash's Avatar
Veteran: Marine Corps
As jdmz recommends.
Princeneo
Jan 20, 2012 04:33 PM
*JG*
Sep 9, 2010 06:33 AM
John_Z
Feb 9, 2009 11:22 AM
AusS2000
Mar 18, 2008 10:35 PM
syellow
Nov 27, 2007 06:53 PM
