Ap2 temp question
Originally Posted by jordannn93' timestamp='1344643496' post='21928480
Just bled it. Still doing getting hot mainly when coming to a stop. Does the ecu have anything to do with it? Would making the fans come on sooner do anything or an upgraded rad? Any input and help is appreciated
By letting the fans come on sooner will do nothing because the problem is that the stock fans do not move fast enough to remove the heat from the radiator, this is why you need SPAL
I dunno it looks like its not running hot going by the ecu reading. I think the ecu changed how the stock temp gauge reads.
Probably because of the ecu. My car gets a little bit hotter than it used to since I have the larger front mount radiator but still has never gone over 205 degrees this summer or ever which is not an issue.
KaNgArOo
Nov 24, 2014 12:23 PM
phoQ
Jul 12, 2009 02:43 PM
