apexi turbo timer
hi again im new so sorry for all the ?s ahahhaahah i just bought a apexi turbo timer too is it easy to install? and does the air/fuel really work on that im running an aem ems please help thanks
jimm
jimm
yes it does i installed it on my car pretty simple
theres the thread that helped me
THANKS to SoCaLismyLife
https://www.s2ki.com/forums/index.php?showt...0&#entry7239920
I also have one of these in my car. It works good for what it is, which is something that simply keeps the car running with the key out.... nothing too special.
As far as the A/F goes, it works well, but it will simply display whatever input you give it. For example, if you give it the signal from the stock ecu then it will show you what your ecu is reading, but if you wire in your wideband then it will display that.
