Using a Apexi VAFC only with turbo?
Old Nov 21, 2006 | 03:21 PM
Oz2's Avatar
Oz2
Default Using a Apexi VAFC only with turbo?
Im wanting to install a turbo system on my 00 s2k but was wondering if I am planning on running low boost say 7-8psi, is it safe to run just a apexi vafc for fuel management? Im new to the turbo thing, any help would be great. I have read lots of treads just cant seem to find anything on this one.
Thanks
Old Nov 21, 2006 | 03:36 PM
Spec_Ops2087's Avatar
I guess you could but its hardly safe IMO. Get either an emanage or an AEM. At least they are guarenteed to work and not have the chance to be "canceled out" as the ECU relearns its maps.
Old Nov 21, 2006 | 04:37 PM
calaceyfl's Avatar
Are you trying to save some $$$? If so 7lb of boost can be achieved with the SC. It's cheaper and you can run the s/c with the stock ECU better than with a turbo. Remember, you can't tune a car with the stock ecu. The AEM EMS is AWESOME though, and it's one of the things that's definitely worth the $$.
Old Nov 21, 2006 | 04:45 PM
news2kroller's Avatar
why not just wait a little longer and get the ems or e-manage so you can get the most out of your already high investment into the car. Its worth it in the end.
Old Nov 21, 2006 | 04:51 PM
calaceyfl's Avatar
100%... I started out with the stock ECU and now I'm kicking myself for not doing it all at the same time. Then WHEN (yes, it will happen) you decide to get more power, you're ready!
Old Nov 21, 2006 | 05:24 PM
j_c_a's Avatar
To answer your question directly: no, it's not safe. Possible yes, safe no.
Old Nov 21, 2006 | 06:11 PM
Oz2's Avatar
Oz2
Thanks for all the replies. Many of you mentioned the e-manage, who makes that and what is the cost. I have always wanted to go turbo, but the AEM cost so much. I guess I need to wait until all can be afforded.
Old Nov 21, 2006 | 06:25 PM
Dsgs2k3's Avatar
its defiantly possible with a good tuner. Turbos are harder to tune though with a VAFC, so it probably wont be the best idea. id say wait for the AEM piggyback to come along
Old Nov 21, 2006 | 06:31 PM
TJTURBO's Avatar
i used a vafc for a year at 7 psi and it ran fine then i saved enough money to buy the aem ems. there are plenty of people that use the vafc with supercharged s2000s i dont see why not with turbo... a boosted motor by s/c or turbo is a boosted motor.e-manage is a nice choice too but they are still piggyback units, nothing like a standalone.
Old Nov 21, 2006 | 07:01 PM
Greddy makes the emanage. Its a very capable system. Although not entirly as good as an EMS, its close. Allows adjustments of ignition and timing as well as larger injectors (however, only limited to +150% bigger over stock)
You can get them used around 450 dollars. Compared to the 1300 dollar AEM, unless your going nuts, the AEM isn't worth it.
Miahjera04
Nov 17, 2014 08:18 PM
Andersonracing
Jun 7, 2013 01:02 PM
Vic81
Apr 12, 2013 05:05 AM
Bkclark
Jun 14, 2012 04:54 AM
waytooslow
Apr 25, 2006 05:28 PM
