bad turbo?
Old Apr 19, 2006 | 08:08 PM
koji187's Avatar
I'm going to replace the oil line going into the turbo with a diff one with less oil pressure. Hopefully that will fix the rattling.......*crosses fingers*
Old Apr 20, 2006 | 04:27 AM
Tinker219's Avatar
We do not supply any kits withOUT restrictors any longer. Unfortunately, I think the oil line isnt going to help much.
FYI, the restrictor is the fitting bolted to the turbo oil feed side, has nothing to do with the line.
Old Feb 8, 2008 | 01:43 PM
sunhita's Avatar
so....
what is the solution guys...?
Old Feb 8, 2008 | 02:17 PM
ya@inlinepro's Avatar
Too much oil pressure isn't going to cause a rattle, but cause smokey situation, not always instantly as well. Make sure there is a proper oil restrictor if the turbo requires one. If its a GT ball bearing, it should have one.
I wouldn't spin the wheel without oil pressure as the seals are meant to have oil pressure in there before the wheel spins.
Everyone has already mentioned this, so just becareful before you damage the turbo further. You should be able to see physical signs for damage. Garrett should warranty it is something were to happen like this as long as they don't see signs of improper installation.
SilverstonedAP2
Mar 20, 2012 02:23 PM
s2kneub
Jul 27, 2009 06:18 AM
chrisg26
Feb 28, 2009 02:18 PM
P'sS2k
May 8, 2008 10:13 AM
