Batbite's: PTuning Kit, Golden Eagle Block, Speed-Factory Built
Old Jul 10, 2011 | 12:01 PM
Batbite's Avatar
Default Batbite's: PTuning Kit, Golden Eagle Block, Speed-Factory Built
So I decided to go ahead and post up yet another turbo / engine build thread....so here it is. After a number of years and 25,000 + miles with a CompTech Super Charger on the car....cylinder-3 gave out on me (mostly my fault...was low on oil and hadn't been dyno tuned / re-checked since in years). So a replacement engine project that started out small turned into more of a "What else do I need".....and has evolved into build below.
Engine Builder, Assembly & Tuner:
Speed Factory Racing - Specializing in Honda Forced Induction
Year: 2001
Fuel To Be Used: 92-Octane Pump-gas
Block: Golden Eagle Bore / Sleeve 87.5mm
Pistons: CP Forged 87.5mm
Compression: 10:1 . . . swapped out for a set of 9:1
Rods: Brian Crower Forged
Head Gasket: Cometic - Standard Thickness 87.5mm
Timing Chain: Toda Racing Heavy-Duty
Chain Tensioner: Toda Racing Heavy Duty
Fuel Management: K-Pro, full stand-alone
Fuel Injectors: Injector Dynamics ID-1000
Fuel Pump: Full-Blown 340 lph
Fuel Rail: Inline Pro
Fuel Pressure Regulator: Fuelab 51502-1 EFI
Map Sensor: SpeedFactory Racing 4-BAR
Springs: Ferrea Competition K20/F20 Springs / Seats / Retainers
Valves: Ferrea Competition Plus
Throttle Body: Pro-Flow Designs Bored & Polished
Ignition: Okada Projects Plasma Direct Coils
Gauges: PLX D-200 ODBII Multi-Gauge 52mm (Boost Pressure, Fuel/Air, Oil Pressure, and EGT)
Turbo: GTX3076R .82 AR
Turbo Housing: Tial V-Band Stainless Steel
Turbo Kit: PTuning
Blow-Off Valve: Turbo Smart
Waste Gate: Turbo Smart
Oil Cooler: PTuning Stand-Alone
Radiator: KOYO
Exhaust: PTuning 3" Dual
Clutch: ACT Heavy Duty Street Pressure Plate
Flywheel: CompTech Lightened
Disc: OEM
Differential: PuddyMod Stage-3 w/ OS Giken Super-Lock LSD
Gear-Set: 4:10's
Motor Mount: Hasport 62A (drivers side)
There may end up being a few other odds / ends, parts that get added but that's what it looks like today. I hope to add pics and video of the tuning as the build progresses. Some of the parts listed are also at the shop...
The Block - Before / After
PTuning Kit
Oil-Cooler
Garrett GTX3076 .82 A/R
Turbo Manifold
PLX Multi-Gauge D-200 OBDII
Koyo Radiator
Okada Projects - Plasma Direct Ignition Coils
Turbo-Smart BOV
Turbo-Smart Waste Gate (Tial V-band)
PTuning 3" Dual Exhaust
The Car
Updated: 7/15 - The Engine is starting to come together. Speed Factory has received all of the parts to begin the engine assembly. The head is at the machine shop with the Ferrea Valves....Should have the engine back in the car middle of next week.
CP Pistons 10:1 Swapped-out for the CP 9:1 due to the 10:1 design sitting above the deck
Brian Crower Rods
Toda Racing Heavy Duty Timing Chain and HD Tensioner
Ferrea Competition Springs / Seats / Retainers
Old Jul 10, 2011 | 12:22 PM
sata3000's Avatar
Damn you went all out .
Old Jul 10, 2011 | 12:26 PM
s2000442's Avatar
Very nice build bro, very similar to mine except for the built engine. Looking forward to seeing what you can do with this build. Good luck.
s2knoob89's Avatar
Nice!
Old Jul 10, 2011 | 12:36 PM
Torque Obsessed's Avatar
Seriously badass. Can't wait to see the dyno results! Like the orange paint too.
How does that PLX gauge work? Does it read off the K-pro? Or do you wire the sensors directly to it? That's a great looking in-dash gauge solution, and I might have to try it.
Old Jul 10, 2011 | 02:30 PM
Batbite's Avatar
Originally Posted by Torque Obsessed
Seriously badass..........
Actually it can make use of both....the D-200 is ODB-II compatible....and reads off of the K-Pro, and it also has specific modules that plug into it....they have a number of them to choose from, boost, fuel/air, egt....etc.
Old Jul 10, 2011 | 02:32 PM
gnehc1's Avatar
Looking good! Subscribed....
Old Jul 10, 2011 | 03:03 PM
passmans2kny's Avatar
doing it right , nice build good luck
Old Jul 10, 2011 | 05:40 PM
Blucky87's Avatar
Copy cat
Old Jul 10, 2011 | 06:50 PM
siadam's Avatar
SF is a good group of guys.
Sent from my iPad2 using Tapatalk
