Batbite's: PTuning Kit, Golden Eagle Block, Speed-Factory Built
Two weeks ago Speed Factory also took 1st Place at the New England Nationals....winning the event with their Turbo car.
Originally Posted by MrC@PTUNING' timestamp='1320081403' post='21115790
Congrats rob, those are fantastic #s on 92 pump gas.
MrC
MrC
Maybe you can add me to your "Custom Cars" list on your website
MrC
your dyno video was added to our customer's video page:
http://www.ptuning.com/html/ptuning_customers_video.cfm
http://www.ptuning.com/html/ptuning_products_video.cfm
MrC
MrC
After about 7,500 miles with the turbo installed; I noticed that the OEM Motor Mount had $hit the bed
It's likely that it happened around the 4,000 - 5,000 mile mark.... but I just didn't notice
The drivers side OEM mount literally tore in half.
After much debate about which mount to replace it with, and a good read through the recent FBM/AVID Motor Mount Thread, I decided to go with the Hasprot mount.
I chose the 62A Urethane hardness rating as it very closely matched the PTuning urethane hardness of 60A
The Hasport mount did require a slight modification to the mounting bracket, where it needed a "Cut-Out" to sit flush against the block. Looking closely at the picture, it appears that Hasport intended to perform the "Cut-Out" but it had been missed on the top plate. I called Hasport and they commented that they had not heard about the issue thus far
Maybe they had two different production runs some got the "Cut-Out"....and some didn't..?
Either way, trimming the bracket took like two-minutes...so it really didn't matter.
All-in-All pretty happy with the end result. There's no added vinration over and above that which was already present from when the PTuning kit was first installed (which replaces the passenger side motor mount)
looks good, i talk to a guy friday, he said he might be able to make me a shield that would force spal fan hot air downward like the greddy shield and not blow onto are filter not sure price.... also seen guy in sponsor sells something similar for $60 shipped. doesnt go whole way across the rad but it would block are spal fans from blowing all that freaking heat into the filter. other then hasport mount, i ordered a inline pro oil filter relocation kit so i dont need take filter tube off every oilchange lol i know lazy....
yea at this point if they made one id wouldnt buy it... they too busy working on scion turbo's and other shit instead of much needed upgrade for their already made s2k turbo kit, which we all spent good money on...i plan to email few guys on here see if we can get a shield made. let you know if i find anything out.. sata you getting hasport mount aswell? also i got the oil filter relocation since got use for half price of what inline pro wants... other then that i been piecing my oil cooler its coming along, need get lines and oil remote thermostat...
