The benefits of a fuel rail
Agree, AEM FPR and a good pump, will do. I run the same parts and I`m above 500hp now.
Let the tuner decide fuel pressure and if you should connect the vacuum hose, they have different opinions on rising rate or fixed fuel pressure.
Thanks Corey, I ll keep that in mind.
In the mean time i'll see if the Id1000s can throw enough fuel down the bores for my full race supercharger setup, If i have problems then I'll look into a fuel pressure regulator and larger pump.
By disconnecting the hose you have a certain pressure all the time instead of rising with the boost as it does connected.
That´s why it´s called 1:1 FPR 1 bar boost will raise fuel pressure 1 bar.
Don't know. I thought I had read that in a thread but don't know for sure. I could be confusing that with my old MR2 turbo which had fuel entering at the number 1 and working its way back. Dual feed were popular on that car for high hp. I could swear I had read people were running slightly higher injector cycle on number four for the S2000 but maybe I am on crack. I had to work 60 hours the last three days so my brain is like mashed taters right now.
Akblues2k
Oct 3, 2011 03:58 AM
