Benson sleeved block
Most people dont understand what oil squirters do. They are mostly there for heat transfer purposes. Squirting oil on the back side of the piston extracts the majority of the heat of combustion from the piston, the rest goes through the piston cylinder wall contact patch. Removing them will increase your pistons operating temperature, and increase your chances of detonation. This extra cooling will be even more important for you, since you are switching to cast iron sleeves. Cast iron's rate of heat transfer is about 60% of that of the aluminum walls you are replacing, and will further elevate your piston temperatures.
I wouldnt remove them if I were you.
The majority of engine builders are also not engineers. The stock f20 and f22 pistons are forged aluminum. Oil squirters are not nesscarry, however your piston will run hotter without them.
Originally Posted by s2000Junky' timestamp='1354068305' post='22175789
[quote name='Alloy Craft' timestamp='1354067389' post='22175770']
[/quote]
Im going to drive this thing on the street so i would think they would be very beneficial to keep but I'm not for sure i wont be runing it 2 minutes at a time I'm a bee running it an hour at a time
thanks a lot for all your input and I hope everyone keeps chimeing in that have built blocks with and without squirters
Sent from my DROID RAZR using Tapatalk 2
Originally Posted by Alloy Craft' timestamp='1354071427' post='22175883
[quote name='s2000Junky' timestamp='1354068305' post='22175789']
[/quote]
[/quote]
I drove from PA to SC many times 10hr trip with blocked oil squirter benson b18c cp pistons turbo ect.. when i parted out block was great still....and i beat on the car just about everyday, you going to get people who claim one is better then other... So in the end just pick for yourself...
Well I decided to keep my oil squirters after talking with Benson for about 20 minutes and going over my complete build and that I will be driving it on the road a lot he said I should keep them
so where should I get my new oil squirters just from Honda or somewhere else
Hey to who ever that has thought about useing benson do it he is one of the most jam up men i have ever delt with
I called him yesterday to find out if he got.tje funds for the block while i was in the e.r. He had already got it sleeved and ready to ship and told me that not to.worry about the block to get better and keep him update on my situation and my blood transfusion
Now idk about the rest of yall but i thought that was the coolest thing that this busy machinist told me not matter then time to let him know how i was and if i needed anything so I consider that taking customer support to a whole nother level
but anyway I'm sure y'all don't care but I just want to share my experience with benson and what a great guy he is thanks
lude92_si
May 22, 2014 07:17 PM
