Best coolant option for vortech s/c
Old Jun 11, 2014 | 12:21 PM
starrman's Avatar
Originally Posted by KillerCom
Yeah, unfortunately I'm in New York so I'll experience some cold nights. Im in a heated garage but my luck I'll take the car out on a 45 degree fall night and it be freezing by the time I'm home. I'll be running water wetter and distilled water and I'll just drain and install 50/50 in the colder months, I don't drive the car from when salt hits the road to about April anyway. Thanks for the input fellas
You would not have a freezing issue while driving...unless it was really cold. I to am in NC, but we got a couple of days in the teens and 20's, I had distilled water and water wetter, never had an issue. In NY, I would certainly throw in some antifreeze when it starts getting into the freezing zone. I would do as you mentioned, just drain and add when it gets cold.
Old Jul 6, 2014 | 06:22 PM
KillerCom's Avatar
Another question for ya'll. I have the vortech aftercooler and a big heat exchanger, 3"x7.5"x26" from frozen boost. How much distilled water goes in this thing? How do I know when it's full?
Old Jul 7, 2014 | 06:35 AM
KillerCom's Avatar
bump
Old Jul 7, 2014 | 08:10 AM
CoolGuy094's Avatar
For my Comptech system with the FrozenBoost HX, I just filled it till it overflowed. Cycled the pump for a while, topping it off as necessary. When I was convinced it was full with no air left in the system, I sucked out a bit of the water from the fill hole and poured in a tad of water wetter. Final fill level was about a half-inch below the fill cap's threaded hole.
Old Jul 7, 2014 | 09:12 AM
Moddiction's Avatar
Former Sponsor
It took me a while to get all air out of system with my upgraded heat exchanger. I kept adding fluid and then turning on pop and off and then adding more fluid. Once it was filled the lever would not go down at all anymore. Did some short drives etc and checked again and didn't go down so level I could tell was good.
Old Jul 7, 2014 | 11:05 AM
Kenny_Stang's Avatar
This is pretty much the method I followed as well, I did squeeze the inlet and outlet hoses to help work out any bubbles. It took a little over half a gallon of distilled water to fill my SOS Racing Heat Exchanger.
Old Jul 9, 2014 | 08:30 AM
SgtDuracell's Avatar
i use chill charger and water.
Old Jul 9, 2014 | 08:51 AM
Suzuka_Joe's Avatar
i run engine ice on my track bike but its too expensive to be running in the S2k. 50/50 coolant works for me with some water wetter added in
abnormals2k
Sep 22, 2010 09:32 AM
abnormals2k
Sep 22, 2010 08:53 AM
S_NeWb
Aug 22, 2007 04:46 PM
bitz
Jul 9, 2005 08:19 PM
OC S2K
Oct 26, 2003 09:38 PM
