Best DIY Battery Relocation
Old Nov 15, 2009 | 06:29 PM
  #31
m R g S r's Avatar
I wouldn't be surprised if it's the AEM somehow. stupid aem.
Old Nov 15, 2009 | 07:01 PM
  #32
dsddcd's Avatar
Originally Posted by Neutered Sputniks,Nov 15 2009, 06:00 PM
I would be concerned that your grounds are solid enough. If there's any kind of resistance there, your battery will see a voltage drop, causing it to discharge.
Rather than solder, why not use something like the terminals used for car audio (uses set screws instead of crimp/solder)?
That was one of the thoughts I had except I purchased a premade cable for the ground and it is made very well. Then I sunk it into a very heavy part of the body. I did everything by the book including removing the paint at the grounding point.
I wonder if it could be my positive cables?
I will measure the voltage at the front switch and battery so see what the delta V is.
Old Nov 15, 2009 | 07:05 PM
  #33
dsddcd's Avatar
That was my only other guess so far I am going to order a meter that measure AMP draw through a mini fuse to test.
It is cheap enough and very handy for future use.
http://www.esitest.com/fuse_buddy.html
Old Nov 15, 2009 | 07:07 PM
  #34
m R g S r's Avatar
go for it. from what you installed, it doesn't sound like that stuff would really be faulty. if the serial gauge was drawing power, it would be lit up, correct? i'm not familiar with the seat belt lock, but that could do it as well. just guessing.
Old Nov 15, 2009 | 07:15 PM
  #35
camuman's Avatar
i used a plain multimeter since your dealing with fairly low amperage. ie less then 3 amps.
oput my multimeter inline between power wire and positive on battery. then started pulling fuses till the draw dropped.
what was funny was when i hooked it up, i saw lke 1 amp draw. and i remember saying WTF, that isnt right, so i started yanking fuses, and nothing was working. so i stopped stepped back, and then it hit me, the damn door was open and the interior light was on. nowonder those kill battiers over night.
anywho, thats how i did it just to realize that wasnt the problem. the battery was bad
Old Nov 15, 2009 | 07:26 PM
  #36
dsddcd's Avatar
Yeah, but I wired everything into the accesory socket using an add a fuse so it has no voltage until the key is on????
Old Nov 15, 2009 | 07:28 PM
  #37
dsddcd's Avatar
Okay, so I measured the voltage at the engine and I got 12.49V then at the battery and got 12.52V. So I am now sure that my cables are good, with only 0.3V of loss I should be doing perfect.
Old Nov 15, 2009 | 07:29 PM
  #38
dsddcd's Avatar
That is what I was going to do but my other multimeter craped out and all I have is a clamp for testing amprerage. I am searching online now for a nice Fluke I want to get a nice one this time.
Old Nov 19, 2009 | 06:40 PM
  #39
dsddcd's Avatar
I should have listened to you and tested the battery first.
Found it. After putting my new Fluke on my battery cable I should no amperage. So using the other chepo meter I was only pulling 0.3 uA so there is nothing sucking the power out of the battery.
So I ended up testing the voltage again and over the course of 5min it dropped 1V?????? I pulled the battery to find it has been leaking acid into the box, WTF, it is a brand new battery.
Old Nov 19, 2009 | 06:46 PM
  #40
JoeyBalls's Avatar
Is it supposed to be on its side like that?
