Best way to set up boost control for temp changes
Old Oct 19, 2012 | 06:56 AM
o'malley_808's Avatar
Default Best way to set up boost control for temp changes
Hey guys, just wondering what the easiest and best form of setting the boost control is. Up here around toronto we range from 100 degrees in the summer to now 40 degrees until I soon put the car away for the winter.
I have my Boost WG base duty map set up to hold around 21 psi. With the colder weather I keep spiking. This is with a 17psi spring and a duty of 20% above 0psi.
What is the best way to add a correction for the colder weather without having to listening to the solenoid clicking the whole time while just cruising or idling?
Old Oct 19, 2012 | 09:56 AM
siadam's Avatar
Bump, good question.
Old Oct 19, 2012 | 06:02 PM
camuman's Avatar
Set up boost wg feedback son. Shit works.
Old Oct 20, 2012 | 05:46 AM
InductionPerformance's Avatar
You need to setup Boost WG Feedback, Boost FB VSS (you should be using this anyway), Boost FB On Error, Boost FB On P+I (works great when setup properly) and Boost Error Duty.
admans2k
Feb 20, 2014 06:49 AM
JoeyBalls
Mar 29, 2009 05:55 PM
2gr84u
Sep 8, 2008 07:06 AM
Reborn56
Nov 5, 2006 06:06 PM
ex-eclipse
Jun 17, 2006 07:34 AM
