BLOW OFF VALVES
Old Jan 25, 2008 | 08:20 AM
Yels2000's Avatar
Default BLOW OFF VALVES
I currently am running a godzilla blow off valve with my comptech supercharger, it came with a bypass one.
My question is when you blow out all that boost when letting off the throttle, will that confuse the aem and make it run lean or rich cause it takes a second to realize whats going on? Rather then having a bypass valve where it blows some of the air back in to the engine?
Just trying to figure out why I keep blowing engines?
I had it tuned by Evans Tuning and they are pretty well known.
Thanks,
Old Jan 25, 2008 | 09:38 AM
passmans2kny's Avatar
im not sure about your question, sorry but i have one for u, how many engines have u blown up?
Old Jan 25, 2008 | 09:48 AM
Spec_Ops2087's Avatar
we have a map sensor not a maf sensor so having an atmospheric bov is ok for our system.
Old Jan 25, 2008 | 03:33 PM
JDMKID35's Avatar
Banned
if you keep blowing motors...time for a new tuner...I know jeff evans but maybe time for someone new
Old Jan 26, 2008 | 06:19 AM
Kondor999's Avatar
Er...only 10psi and he's blowing engines?!?
I think we got a bigger problem here than a BOV. Anyway, what Spec_Ops said about the sensor is 100% correct.
Old Jan 26, 2008 | 06:53 AM
ChefJ's Avatar
Blowing off the air should cause a rich condition. You won't blow an engine that way.
Old Jan 26, 2008 | 09:21 PM
Jumbalius's Avatar
ok, so if im running very lean, it could be my vortech BOV needs adjusted ??? I have my FPR adjusted but still lean a little bit. any suggestions related with the BOV?
Old Jan 26, 2008 | 11:15 PM
SoCalIsMyLife's Avatar
if u're running very lean then you need to either adjust the FMU, or if it's not adjustable, either put in washers above the spring or get a VAFC to tune the car with. Running lean has nothing to do with the BOV.
Old Jan 27, 2008 | 08:23 AM
Jumbalius's Avatar
Ok I did put a slightly, i mean very slightly larger washer in there, since it is the factory Vortech one it's not adjustable.... Thanks man....
PS - Guess i really need to get that A/F ratio gauge to tell for sure! Thanks
ryanmdel
Dec 3, 2018 05:26 AM
s2kseven
Mar 20, 2012 03:30 AM
whasupman
Sep 19, 2009 09:58 PM
simonprelude
Aug 13, 2006 02:09 PM
