Blue smoke after turbo install
Old Jun 5, 2009 | 08:03 AM
  #41
HMFIC's Avatar
hey i appreciate the help. didnt know lines and fittings had that much of an impact!!!
i'mma keep this updated
Old Jun 5, 2009 | 08:37 AM
  #42
MADjdm's Avatar
the turbos oil/coolant lines are commonly overlooked, but they are just as important as any other part of a turbo's setup.
I'm in the proccess of trying to put mine together now and it can be a headache!
Old Jun 5, 2009 | 08:42 AM
  #43
HMFIC's Avatar
wats funny is, i been messing with turbo's for years with my other cars and this is the first that i've encountered this lol.. AND THIS IS MY 2nd TIME TURBOING MY OWN S2000!!!! lol
i have everything else squared... just this little issue
Old Jun 5, 2009 | 12:00 PM
  #44
Ramocheese's Avatar
Turbo "seals" do not blow. A seal is a metal ring much like what you find around your pistons. The only way a turbo is going to blow oil out into the exhaust is:
1. Oil backs up into the bearing housing. This is usually caused by excessive crank case pressure, or a kinked/obstructed drain
2. There is bearing failure and the shaft is able to move freely enough to damage the piston ring seal.
If the turbo shaft still seems tight and it is smoking, 99.9% of the time it is because of #1.
Old Jun 5, 2009 | 04:08 PM
  #45
HMFIC's Avatar
I just got the fitting installed with with smaller exit hole...
gotta drive around with someone following cuz i sure cant see the smoke.. never did in the first place lol
i was also told by PFAB that the fitting is too large so to put a restrictor which i pretty much did... and to get the krank vents installed..
so i'm guessing the oem PCV isnt strong enough that i could put in the rubber hose between the intake mani and the valve cover?
Old Jun 5, 2009 | 05:05 PM
  #46
GDM S2K's Avatar
I've heard diff things with the pcv I ran 15psi with no problem I run the supra pcv now just cuz it was 2 bucks LOL
Old Jun 5, 2009 | 05:14 PM
  #47
HMFIC's Avatar
really? where did you get the supra one? like from auto zone?
wat year supra? twin turbo i'm guessing right?
cuz if i can get one at the advanced auto, best believe i'mma go there tomolo to get one hahahaha
anyways.. B and T showed me the fitting, it was DEF alot bigger than the one they put in.... i mean its litterally like twice the size of the new one they put in...
a very trusting friend that owns a shop said i should be fine with the fitting.. and if not.. to change the oil drain line so... i guess its a worth the shot lol
Old Jun 5, 2009 | 05:29 PM
  #48
GDM S2K's Avatar
Yup advanced has them do a search for the diy on the supra pcv
Old Jun 5, 2009 | 05:32 PM
  #49
HMFIC's Avatar
how hard can it be? just fit the pcv between the valve cover and mani in the hose right?
Old Jun 5, 2009 | 05:39 PM
  #50
GDM S2K's Avatar
one side of the pcv is larger on the supra pcv I hollowed out the oem one for my 90 off the vc and used a insert from a larger hose like the diy
