Blue Smoke Under WOT
Old May 2, 2016 | 01:02 PM
CBRs2krr's Avatar
Default Blue Smoke Under WOT
I have a Vortech sc and I noticed while my car was on the Dyno, it was giving out blue smoke under wot but not throughout the rpm band. My guess is that I am not running a catch can and the residue oil is being burnt. I plan adding a catch can setup this weekend. I was wondering what else I should be looking for. The car only has 25k miles and I haven't noticed any blue smoke under idle, moderate throttle input or any other time. Hoping the catch can will solve it. Any other suggestions would be helpful.
Here is a video of it on the Dyno.
https://youtu.be/YaHDGE8X188
Old May 2, 2016 | 02:54 PM
Chance S2K's Avatar
Go by Autozone/Walmart and make a cheap DIY catch can in the next few days and see if that helps at all.
This looks like a good setup, but I wouldn't do the steel wool stuffing: http://www.team-bhp.com/forum/diy-do...catch-can.html
Edit: I'd highly recommend modifying that can that's pictured though. Put a filter to breathe to atmosphere where the cap normally goes and run the actual can lines close to the top but not the tip-top of the bottle.
Old May 3, 2016 | 10:55 AM
CBRs2krr's Avatar
Thank you. I'm going to give the catch can a try and hope that resolves it.
Old May 3, 2016 | 02:20 PM
soulicious's Avatar
Seems like a lot of blue smoke. Are you burning a lot of oil and how do your spark plugs look? Maybe test your PCV and perform compression and leak down tests.
littleterrorist
Nov 5, 2015 07:51 AM
cheddaboy
Feb 13, 2014 02:32 PM
coquinn
Jul 2, 2002 07:22 PM
MVC Tuning
Jan 2, 2001 08:54 AM
