Boost with 11.5:1 compression setup
Old Jun 4, 2009 | 04:06 PM
siadam's Avatar
Lower compression offers a larger window for tuning, thats a fact...the higher the comp goes, the smaller the room for error is.
Keep that in mind.
Old Jun 4, 2009 | 05:07 PM
s.hasan546's Avatar
wut kind of "octane booster" are you using? take your car to TonyT1 i think hes in texas. he will tune a stock motor to 400+ whp at stock cr. hes the only person id go to in texas. did alamo ever tune a S?
Old Jun 4, 2009 | 05:14 PM
JuicedS2K's Avatar
i would like to know as well, in all cases that i have been involved in or researched, the bottle says it will raise the octane 7 points or what not, it actually turns out being .7 points, most wont even raise it 1 point, please someone correct me if i am wrong.
Old Jun 4, 2009 | 06:12 PM
lookinco's Avatar
I am running my stock JDM AP1 motor with 11.7cr and 13.5psi supercharged with no knocking or detonation. I am also running 50/50 water/meth.
Old Jun 5, 2009 | 04:20 AM
S2K_2003's Avatar
Hey, LOOKINCO
What kind of WHP are you putting out??
Old Jun 5, 2009 | 04:28 AM
S2000_FUN's Avatar
So running a stock Ap1 engine with 11psi pulley on a comptech SC is very dangerous? I am not abusing the engine or track racing but is it really dangerous? Is the limit for stock AP1 compression 10psi pulley?
Old Jun 5, 2009 | 04:37 AM
iDomN8U's Avatar
The universal psi for stock ap1 is no more then 9psi
Where did this # come from? not sure...
But if you're having 0 detonation at all RPM and can run 91 octance through any type of weather be it 100+ degree's F and your A/F ratios look good then 11 might be fine.
S2K_2003's Avatar
From what I have been reading, +104 Super Octane booster adds another 4-6 octane so, I am running 93 octane it bumps it up between 97-99 Octane, Correct me if I am wrong, but that's what i gathered from a few articles
Old Jun 5, 2009 | 05:35 AM
JuicedS2K's Avatar
That would be cool, anyone else have info in this?
Old Jun 5, 2009 | 05:41 AM
4evertopless's Avatar
Not even close.
Octane points are one TENTH (0.1) of an octane number ie. 93
Most octane boosters raise you 5-10 points, however there are some that you may find in the local parts stores that will genuinely give you 30-40 points.
Klotz is said to give like 10 octane numbers, but Ive never seen it here locally.
