Boost with 11.5:1 compression setup
Old Jun 5, 2009 | 05:43 AM
  #21
4evertopless's Avatar
oh here is the 104+ stuff
"Designed for off-road use in 2 and 4 cycle Sport Gasoline Engines. Increases octane effect up to 7 points. Extra concentrated for high-compression engines. Stops knocks, pings, run-on, and overheating caused by low octane fuels. Cleans fuel injectors and carburetors. Dynamometer tests show Super 104+ significantly increases horsepower in high-compression engines. Safe for fuel cells, liners, gaskets, o-rings, catalytic converters and oxygen sensors. Does not contain lead, alcohol, aniline, toluene or MTBE. Treats up to 22 gallons."
Old Jun 5, 2009 | 05:56 AM
  #22
Oh and one more thing from me, you probably dont need octane boost with 11.5:1, if you have 93 locally. Our cars stock are tuned for 91...so
Not even a little
Old Jun 5, 2009 | 06:35 AM
  #23
iDomN8U's Avatar
Can you trust those things??
Old Jun 5, 2009 | 07:15 AM
  #24
s2000Junky's Avatar
Originally Posted by S2000_FUN,Jun 5 2009, 04:28 AM
So running a stock Ap1 engine with 11psi pulley on a comptech SC is very dangerous? I am not abusing the engine or track racing but is it really dangerous? Is the limit for stock AP1 compression 10psi pulley?
If your not getting any detonation then your fine, its how your car is tuned which is what will dictate how safe it is. Its true that the higher comp you have the window becomes smaller for dialing in timing for detonation tendencies, its all about detonation, so that doesn
Old Jun 5, 2009 | 08:27 AM
  #25
S2K_2003's Avatar
Does anyone have Part #'s on colder burning plugs??
Old Jun 5, 2009 | 09:14 AM
  #26
s2000Junky's Avatar
2668 is the part number for the NGK #8 irriduim plugs, one heat range colder then stock.
Old Jun 5, 2009 | 09:57 AM
  #27
S2000_FUN's Avatar
The universal psi for stock ap1 is no more then 9psi
Where did this # come from? not sure...
But if you're having 0 detonation at all RPM and can run 91 octance through any type of weather be it 100+ degree's F and your A/F ratios look good then 11 might be fine.
[QUOTE]If your not getting any detonation then your fine, its how your car is tuned which is what will dictate how safe it is. Its true that the higher comp you have the window becomes smaller for dialing in timing for detonation tendencies, its all about detonation, so that doesn
Old Jun 5, 2009 | 10:20 AM
  #28
devs2k's Avatar
Originally Posted by S2K_2003,Jun 4 2009, 12:23 PM
Okay, so I rebuilt my motor recently, It has been sleeved, with 87mm 11.5:1 JE pistons
What I am trying to determine is weather to go SC or Turbo, and how much Boost can a sleeved block with 11.5:1 can take, for everyday driving.
Thanks for any input
i know you do not want to hear this
open it back up and put some 9.x:1 pistons in there
Old Jun 5, 2009 | 11:14 AM
  #29
s2000Junky's Avatar
[QUOTE=devs2k,Jun 5 2009, 10:20 AM] i know you do not want to hear this
Old Jun 5, 2009 | 11:17 AM
  #30
devs2k's Avatar
Originally Posted by s2000Junky,Jun 5 2009, 03:14 PM
Unless he's planning on a 500whp turbo
Is there any other way?
jk
