Boost is incorrect help!
Old Aug 11, 2011 | 11:59 AM
bois2k's Avatar
Default Boost is incorrect help!
Hey whats up guys im having a problem with my car.. it is tuned on aem v1 set to boost by speed for 15psi but i recently noticed it holds only 5psi trough all the gears at any speed was wondering what could b the problem any help is apriciated thanks ahead of time!
Old Aug 11, 2011 | 12:16 PM
3en's Avatar
3en
You have a boost leak somewhere. Check couplers, nuts(manifold, turbo, and wastegate) bolts, and vac. lines to start with.
Old Aug 11, 2011 | 01:05 PM
bois2k's Avatar
yeah i checked all my vacum lines and the couplers i could see have to remove the bumper to see the rest but everything under the hood looks good
Old Aug 11, 2011 | 01:13 PM
Sideways's Avatar
A boost leak detector is cheap and/or easy to make. It is absolutely essential to verifying there is no leak. Do it.
https://www.s2ki.com/s2000/topic/874...#entry20690838
Old Aug 11, 2011 | 01:50 PM
bois2k's Avatar
ok sure will bro thanks! could this also b a sign of a bad turbo?
Old Aug 11, 2011 | 02:09 PM
camuman's Avatar
Did it use to work correctly?
Old Aug 11, 2011 | 03:06 PM
bois2k's Avatar
yeah it was working good not sure whhen it stoped boosting to 15psi tho
Old Aug 17, 2011 | 01:33 PM
bois2k's Avatar
found the problem the pin on the harness where the mac solenoid connects to the ems had came out
Charper732
May 21, 2017 07:14 PM
p0staboy
Jul 17, 2013 06:54 PM
Planets
Jun 13, 2010 06:58 PM
batikan
Nov 16, 2007 06:40 AM
Reborn56
Nov 5, 2006 06:06 PM
