View Poll Results: Do you use a boost leak detector?
No
39.13%
Yes, I made my own boost leak detector.
30.43%
Yes, I bought a pre made boost leak detector.
8.70%
What the hell is a boost leak detector?
21.74%
Multiple Choice Poll. Voters: 23. You may not vote on this poll
Boost leak detectors
Old Jun 8, 2011 | 11:29 AM
Sideways's Avatar
Default Boost leak detectors
What are you using to check for boost leaks? Twice I have had boost leaks pop up out of nowhere and having a boost leak detector would make finding the leak much easier. Last time I found it while on the dyno.
I thought about making my own and then decided to google it and ...pre made, ready to use, nicer than I could make, reasonable prices too. I just ordered up a 4 inch one for the tool box.
Old Jun 8, 2011 | 11:33 AM
s2000442's Avatar
Link to what you found?
Old Jun 8, 2011 | 01:14 PM
Sideways's Avatar
Rather than driving around to the hardware stores and auto parts places I just ordered one.
http://www.turboboostleaktesters.com/servlet/StoreFront
http://www.myturbodiesel.com/1000q/m...-DIY-check.htm
Old Jun 8, 2011 | 01:27 PM
jb34304's Avatar
The only time I have had a boost leak is when the charge pipe came off . I am sure if you logged some info off your ems you could easily tell if you are leaking boost. Not that I have tried it, but if you have an air compressor @ home you could use that to try and find a leak.
Old Jun 8, 2011 | 02:25 PM
Deception's Avatar
Ive actually made a few of them.. cost about $20-25 in parts from Home Depot, its really just an excuse to go there & buy other stuff though lol
Old Jun 8, 2011 | 07:42 PM
passmans2kny's Avatar
everytime i go to homedepot i spend 4 times as much as intended, this is a cool idea I'm gonna make one of these soon
Old Jun 8, 2011 | 07:53 PM
ScorpioMk's Avatar
Ive always just improvised, but those who havent done this I highly recommend you give it a shot. Basically 100% of the cars I have done it to have a leak somewhere. Whether from a clamp being at a bad angle or having a hole rubbed in a pipe by some steel, theres been at least a sight leak.
Old Jun 12, 2011 | 01:27 PM
Sideways's Avatar
It arrived 4 days after I ordered it. Very simple and easy to make your own as has been stated before. You need a drill and tap to make one of these. If you skip the gauge it can be made for very cheap. It was simple to just order it.
[attachment=3887SC00216.JPG]
Now to the task at hand, looking for boost leaks and solving them.
Attached Thumbnails Boost leak detectors-dsc00216.jpg   Boost leak detectors-dsc00217.jpg
Old Jun 13, 2011 | 07:49 AM
siadam's Avatar
Thats what mine looks like, except I didn't put a pressure gauge in it, I just use the gauge on the compressor so I know how much is in the system, or look @ your boost gauge if you have one. I also have used a tire gauge once it's full to see how much it's holding.
Old Jun 13, 2011 | 01:39 PM
Sideways's Avatar
I have a big boost leak. I have to modify the after cooler to stop the leak.
