Boosted ap1 smoking at idle
Old Oct 22, 2011 | 02:51 PM
alanpikku's Avatar
Originally Posted by S2000 Cabrio
are you running a catch can that has a breather filter?
It's vented to the atmosphere, and i'm running a Supra PCV.
Old Oct 22, 2011 | 02:53 PM
alanpikku's Avatar
Originally Posted by neoleooo
Originally Posted by alanpikku' timestamp='1319136878' post='21087297
[quote name='neoleooo' timestamp='1319094010' post='21085792']
most likely it the turbo. how long have you had the turbo? try to move the shaft from the turbo to see if it has any play. move it up and down and pull it in and out.
Thanks, I will check it out. Shaft play seems good, but turbo has rough spots when spun by hand.
when you say "shaft play seems good", do you mean its moving when you wiggle it. because its not suppose to move a lot. its only suppose to spin
[/quote]
You can wiggle the shaft back and forth, but barely.
Old Oct 23, 2011 | 09:11 AM
hurtgen's Avatar
easy way to check if oil is being blown by the chra in to compressor housing and ultimately burned off - pull the charge pipe off the turbo and see if there is oil on the walls of it. the good thing is if you see oil in there, you have found the problem. bad thing is that the oil has now gotten in all yuor charge pipe, intercooler, bov, throttle body, map sensor, intake manifold and everywhere else in the world including north korea.
you can clean the intercooler easy by pulling it off, pouring some gasoline in side it, shake it a bit, dump out gas, repeat until gas comes out clean.
good luck, let us know what you find. -joe
btw, all turbos, both journal and ball bearing, will have varying shaft play. the way you described your shaft play sounds terrible. it should spin freely with no resistance, with or without oil in it.
HawkS2K
Jun 5, 2016 12:42 PM
tds85
Jun 21, 2014 11:59 AM
brummimatt
Dec 30, 2012 11:42 AM
f22cjh4
Oct 2, 2012 07:30 PM
Competitor9
Aug 22, 2011 12:40 PM
