Boosting, which to do?
Old Aug 18, 2010 | 05:42 AM
  #71
bluemetals2k's Avatar
Originally Posted by soulicious,Aug 18 2010, 01:25 AM
Just get the AEM 1052U (not 1052) EMS and AEM serial gauge and call it the day for gauges. It's simple to install.
Uh no, he can get a used 1012, 1052, or 1052u the differences are minor, look at Sideways hes running a 1012 on his 500whp vortech sc setup
Old Aug 18, 2010 | 07:32 AM
  #72
Importedpower's Avatar
so many people are on so many different pages here... im laying out what i should get, and currently i am looking for a shop that can tune, i can install the SC my self with one of my friends no problem, its the tune thats gonna be a bitch... i dont know of ANYWHERE that does tunes at all around columbia SC, and ive looked around and made some calls
Old Aug 18, 2010 | 07:46 AM
  #73
erikvanden's Avatar
[QUOTE=Importedpower,Aug 16 2010, 01:52 PM] Ok, to sum it all up, im having my engine checked out soon, and im going to either turbo or SC the engine.
Old Aug 18, 2010 | 08:07 AM
  #74
soulicious's Avatar
I was not saying anything else was inferior...just a recommendation since the wiring/install is more simple for serial gauge
Old Aug 18, 2010 | 08:12 AM
  #75
chef-j's Avatar
Not only you, there are many guys have to drive few hours to get a tune. Post on local section, they can help you more than this section.
Old Aug 18, 2010 | 08:52 AM
  #76
Originally Posted by erikvanden,Aug 18 2010, 07:46 AM
I have a CT SC. it has been good so far although it tends to make lots of rattling noises when its cold and when getting into gear.
Anyway if u get a SC your probably best staying around 300WHP or around whatever the kit comes with. Otherwise your going to end up having to spend over 2,000 easy to get that extra 50whp. You will also probably end up spending more than you think. There is always little thing.
Turbos are also a good option but they might be harder to install and they will require tuning unlike a SC which you can just about throw on and go. You can probably get a lot more power out of a turbo though. I just don't like the idea of having boost at such low rpms and thats what turned me away from turbos. that and they have overheating problems.
I would also plan on buying a new clutch and it would be easiest to do it before you go FI. Other than that there isn't any mechanical thing that you would need. The engine and tranny can easily hold the power. Although you should know that stock diff is very week. you don't need to replace it but just know that the car isn't built to be launched. People usually only blow them launching the car.
And for anyone telling him to search because this is posted all the time, would you spend 6- 9K without posting?
thanks for info, ive heard not to launch them, i was wondering how difficult it would be to get something a bit stronger for that one? i was going to get a new clutch, i got a hardtop coming, and i was looking at wheels and coilovers aswell... but i havent seen much bout the launch issues other than i shouldnt do it
Old Aug 18, 2010 | 10:29 AM
  #77
HMFIC's Avatar
I'll say from experience here with the 1052U here...
There is a reason why when they made the 1052U, they made it as an option. Now they don't even make it as an option for the series 2.
why?
Because the 02 sensor has been known to not work properly after awhile, and if your running your car to read off of that sensor to make those calculations for you, and it fails...you can guess what it will do with the air/fuel mixture.
I've had 2 aem 1052U's and both times *without my knowledge* the 1052U was set to NOT read off of the sensor and only read within what the tuner tuned the car on.
That's why it's better to get a 1052 and get a separate stand alone wideband.
AEM has even admitted this as well...
I was def kinda confused because you'd think that it would be good to make the calculations per what it reads for most efficiency, but because of the failures and cost...they decided to nix it and just cut the UEGO option when they made the series 2.
maybe one day they can do something about it
Old Aug 18, 2010 | 10:56 AM
  #78
soulicious's Avatar
You can use a different O2 sensor other than the one that comes with AEM (Sensors --> Oxygen Sensor --> O2 Sensor #1). I am not debating what EMS is best, I was just making a suggestion to the OP because he was concerned about gauges . I retract my original suggestion.
Old Aug 18, 2010 | 11:26 AM
  #79
HMFIC's Avatar
It's not just the o2 sensor but i understand what your saying.
Old Aug 18, 2010 | 05:02 PM
  #80
erikvanden's Avatar
If you don't blow your rear diff normally when you buy a new one they will give you a core for your stock one. Although it still isn't cheap and if you don't do it yourself I'm sure it would easily be over $1000 for a diff that wouldn't be much better than stock. Not to mention if you have some power there is otherstuff besides the diff that can go out.
I don't plan on putting a new diff in myself because I don't want to pay to get it done and I don't like doing work under the car. I don't have a lift or impact tools and everything is rusted on. It's rare that you hear people blowing the diff without launching the car and if you do they probably track the car hard and put down lots of power.
If you put a blower on it might have to come off to put the clutch in so I would do the clutch first otherwise you might be in the same boat as me.
I would wait on parts unrelated to your FI set up. When buying gauges and fixing little minor problems that come up you might spend more than your planning. Wheels and coilovers also probably aren't going to do much performance wise. People normally get wheels for looks or tire selection and the stock suspension is great. I believe people normally only get coilovers for their adjustablity for the track and that some aren't any better than stock. Although I'm not sure about this.
good luck. Sorry for the spelling im just in a hurry.
btw. If you installing a wideband you need to weld a bung for the sensor. I found the easiest way to do this is to either buy a HFC with an extra bung or a testpipe and weld it in there. This held my install up a few weeks because all my exhaust bolts were rusted on and a special torch was needed to weld the bung. that plus shipping time.
