Borg Warner EFR and S hybrids?
Old Apr 2, 2012 | 09:41 AM
B5254T4's Avatar
Default Borg Warner EFR and S hybrids?
I heard about a nice hybrid turbo today, regular S serie but using EFR compressor wheel.
Anyone know who makes it? Fullrace? Any BW dealers on this board?
Old Apr 2, 2012 | 03:06 PM
ScorpionT's Avatar
Its the billet S362/88-75. Its definitely a nice turbo, one of the best in that size.
Old Apr 2, 2012 | 04:23 PM
Irishflame27's Avatar
like Scorpion said its called the "FMW" its a hybrid between a standard Borg Warner Airwerks S300SX 83-75 (61mm) and 88-75 (63mm)and an EFR 8374, it uses a slightly smaller compressor 61.4mm inducer & 83.4mm exducer FMW forged wheel, and you can choose between 2 different turbine wheels depending on what you want, if you want maximum spool, they offer a "flat tip" which comes from the Airwerks 83-75, IF you want maximum top end they suggest the "cupped tip" which comes from the 88-75.
This turbo is ABSOLUTLY AMAZING and is by far the best turbo choice in the 62mm turbo selection. DO IT!!!
Old Apr 2, 2012 | 08:12 PM
B5254T4's Avatar
But I heard something about a 67 or 68mm, please tell me it´s true. 62 is too small I´m afraid.
Thanks for the info guys, still trying to make up my mind about the damn turbo...
Old Apr 2, 2012 | 10:13 PM
ScorpionT's Avatar
Youre talking about the S400SX 67mm. It uses the compressor from the 9180 but paired with a standard 83mm turbine wheel. The turbine is a little larger than what I would prefer for most applications (I like the 79mm) but its a turbo geared more for racing.
Old Apr 3, 2012 | 04:57 AM
passmans2kny's Avatar
fmw 88-75 is such a sick turbo
Old Apr 3, 2012 | 06:50 AM
with the S400SX FMW 67mm, Jeff Evans was able to break the true sreet record, and run an 8.98 in his integra, this turbo has set the bar for 67mm turbos into the 1000-1100whp range, this turbo is also another amazing choice!
SilverstonedAP2
Mar 20, 2012 02:23 PM
JoeNapolitano
Feb 14, 2011 05:21 AM
AndyFloyd
Aug 5, 2009 08:11 PM
BMACMAC
Jan 20, 2007 05:06 PM
Polimangas
Sep 12, 2006 06:11 PM
