borg warner input please !
Old Feb 27, 2013 | 03:43 PM
08s2000CRbackinblack's Avatar
Default borg warner input please !
looking to get back into the boosted game and am looking to get a borg warner. i was looking more so into the BorgWarner S300SX 8375 Turbo S360. ive had everything for log manifolds with sc-61's to full race twin scrolls with gt4088 in other cars. with that being said i think im leaning towards getting the non-scroll t3 option for simplicity and im not looking to make 700+hp like i was on the gt40 setup. unless i find an amazing deal on a twin-scroll manifold im gonna go with the t3 .70 singlescroll option when getting a borg warner. im looking to make around 400hp DD but may bump it up to 500-550 range eventually but nothing crazy. so should i go with this turbo ive been looking at or a different model s300sx. i do want quick spool and probably wont even run more than 15psi of boost so spool up is pretty important.
thanks for any advice
Old Feb 27, 2013 | 03:54 PM
Jin_SK's Avatar
Full race T3 EFR kit
Run that with the 7670 and call it a day.
Old Feb 27, 2013 | 04:47 PM
passmans2kny's Avatar
s300 fmw is a great choice also
Old Feb 27, 2013 | 05:30 PM
wy2slow_z's Avatar
another +1 for s300sx
Old Feb 27, 2013 | 05:52 PM
d-bo's Avatar
not borg warner, but bullseye power.. basically the same thing.
i have an s256. kind of in between a 3076 and a 35r. i think that's what you're looking for.
i just so happen to have one for sale, with a pfab elt kit! woah, crazy
i've got that inlinepro kit too
Old Feb 27, 2013 | 07:01 PM
ScorpionT's Avatar
If you plan to always run pump fuel, even at the 500-550hp levels, the S360 or S362 will work. If you plan to use meth, run race fuel, or even E85, I would use a smaller S200SX.
Old Feb 28, 2013 | 02:45 AM
camuman's Avatar
S362 ftw
Old Feb 28, 2013 | 08:11 AM
Redline S2K's Avatar
Why do you recommend this, if you don't mind explaining.
Old Feb 28, 2013 | 10:24 AM
ScorpionT's Avatar
A smaller turbo produces more heat at a given mass flow than a larger turbo will. This means the smaller turbo has a more narrow safety margin for tuning. When running only pump fuel the larger S300 turbos are a better choice, but meth, race fuel, or E85 will allow running a smaller turbo safely. The smaller turbo will spool quicker and be more streetable, which is always the ideal.
Old Feb 28, 2013 | 11:18 AM
Originally Posted by Redline S2K' timestamp='1362071494' post='22370643
[quote name='ScorpionT' timestamp='1362024098' post='22369606']
[/quote]
Thanks for the explanation, didn't think about it that way.
