bosch 1000cc saturated injector issue
Old Jun 4, 2009 | 07:39 PM
sbrodacz's Avatar
Banned
Default bosch 1000cc saturated injector issue
I bought bosch 1000cc saturated injectors in Feb from Inline Pro. I had them installed in March. For some reason the did not fit right. Everythings working fine, but just does not look right. Spacers were needed to fill the gap. After looking at others, they seem to fit perfectly. Here are some pictures to show what I am talking about. Any ideas on what the issue is?
Old Jun 4, 2009 | 08:50 PM
tony1's Avatar
Looks like the studs holding the rail on are not OEM?
The factory ones (mounting studs) are steel and have a hex on the bottom to tighten them into the manifold.
Did you have aftermarket injectors before these, or stock injectors?
Old Jun 4, 2009 | 09:18 PM
sbrodacz's Avatar
Banned
I had 675's before. I believe they were deka's. I don't think the injectors and fuel rail came with other studs (everything was boughten with the turbo kit). I'll have to look.
Old Jun 4, 2009 | 09:45 PM
tony1's Avatar
That's a stock rail. The studs must have been replaced when the old injectors were installed and the reason yours looks different than the rest.
Old Jun 4, 2009 | 10:08 PM
TRBOKEV's Avatar
Maybe 2 sets of gaskets/o-rings under the injectors? they usually sit flush and yours seem up.
Old Jun 4, 2009 | 11:38 PM
Boofster's Avatar
I got he 725's from Evans. Reused both the top and bottom o-rings from the stock injectors. It's an '06 though so definitely diff looking than yours.
A shot from Tony at T1:
Old Jun 5, 2009 | 08:06 AM
sbrodacz's Avatar
Banned
new oem orings were used. Honda dropped them off. What a min, that's the stock rail? I thought I had a new one with the kit? Could it be causing restriction issues?
Old Jun 5, 2009 | 10:05 AM
tony1's Avatar
The stock rail is more than sufficient.
The newer S2K's use a steel rail, the older ones an aluminum rail.
Old Jun 5, 2009 | 10:36 AM
sbrodacz's Avatar
Banned
Thanks Tony. I found the oem studs too.
ChefJ
Jan 15, 2009 04:57 AM
HMFIC
Feb 21, 2008 05:00 PM
Asura
Aug 4, 2005 11:50 AM
1Randyc
Jun 6, 2002 07:03 AM
