Bov replacement on Comptech System
Howdy...
I'm currently running a comptech supercharger (9 lbs up to 12 lbs boost) with a FMIC. The bosch bov that came with the original aftercooler setup was leaking so after some searching here I replaced it with a Turbosmart Kompact valve. Since i'm not recirculating I have it set to vent off the excess boost. Unless i'm at idle or WOT the valve pretty much vents constantly (kind of a fluttering noise) while driving. Is this normal? I thought maybe the spring was too soft but that wouldn't make sense considering it's for turbo applications which run higher boost than i'm running.
TIA
Edit: https://www.s2ki.com/s2000/topic/793...pressor-surge/
Read this thread from a while back which was helpful. One guy posted this:
I did note that when I installed the BOV, even on the hardest spring setting the piston stayed open slightly. However, following the general install instructions (probably for a turbo motor) it said to make sure the piston was closed at idle. To make it close I added in some shims to make the piston fully close. Considering a s/c does make a little bit of boost at idle should I remove the shims and set it so the piston is slightly open?
TIA
It's the BOV. You can't use the HKS SSQV. The local shop told me they tried with s/c setups and it's no go. I know it's the shit for turbos and we love it but for s/c's, it just doesn't open properly. You need something really loose like a Greddy Type-R or Type-S, etc. Do a search for others that also work. It sounds exactly like your issue as the s/c bov will stay open at idle (you make like ~1psi of boost at idle). The HKS just springs closed.
I had the same problem. My setup is a novi 1000 with FMIC and 3.0' pulley. I installed a synapse bov and was fluttering. The problem wasn't the spring. The novi 1000 blows too much air that this kind of bovs can't handle. SO we thought that might be a good idea to install a second bov. So we did and the result was excellent. No fluttering no nothing. Works perfect.
I am picking up my car tomorrow fingers crossed it's gettin tuned on the new engine setup and 3.2" pulley
If I do end up bringing my baby home I can gladly take some pics I have no clue on how to upload em on here though I will have to work it out!
I was hoping to post up some pics but looks like my car needs another pump the car made 389whp very easily at 7000rpm which kind of puzzled me because I was expecting a bit more from a 340lph pump. But anyway when I do get the car back I can post up some pics
