Bov replacement on Comptech System
Old Aug 24, 2011 | 05:02 AM
EOE's Avatar
EOE
I am still confused, so how do I know if the BOV is working properly on a SC. Every time I let go off the gas pedal it opens up and I hear it release air. Once back on gas it closes.
However it is not open at idle and does not blow off below 3k rpm.
I have Turbosmart.
Old Aug 24, 2011 | 07:17 AM
donaldmejr's Avatar
Originally Posted by manny-s2000
I was hoping to post up some pics but looks like my car needs another pump the car made 389whp very easily at 7000rpm which kind of puzzled me because I was expecting a bit more from a 340lph pump. But anyway when I do get the car back I can post up some pics
Wait you need another pump other then the 340lph?? There's no way your maxing out the 340lph.
Old Aug 24, 2011 | 07:18 AM
donaldmejr's Avatar
I have Turbosmart.
my oem one always blows out at idle...contact forged motorsports or paxton
Old Aug 24, 2011 | 09:37 AM
mrscbw's Avatar
I have Turbosmart.
That sounds normal to me, It should close every time u get on it or else you'd be leaking. Blowing off below 3k? It should open when you release but whether you hear it blow off is a different story. You need pressure to hear that blow off sound and I don't know if you build enough pressure under 3k to hear it. I would lower the spring tension and check for boost leaks. Have it as loose as possible without boost leaks on max psi. I think this would give you best throttle response.
Old Aug 24, 2011 | 11:17 AM
donaldmejr's Avatar
on my 9psi pulley I don't really hear the stock BOV at light throttle but I can still feel it at idle. Forged told me that they have seen SC'er guys run a spring for there 15psi that turbo guys may use for 30+ psi. but I have no real world testing to say yes or no
Old Aug 27, 2011 | 04:33 AM
package's Avatar
The previous owner of my superchager had no issues with the bov. He had an aftercooler setup. I installed the supercharger with a FMIC and the bov started fluttering. When we installed the second bov the problem was solved.
CTECHs2k
May 17, 2007 02:35 PM
bumpins2k
Aug 11, 2005 02:35 PM
jdmdohcpower
Oct 15, 2004 04:25 PM
Pok
Mar 22, 2004 10:59 AM
doorman
Mar 7, 2004 11:43 PM
