BRP/SOT Hotside SC Install
Old Mar 12, 2008 | 10:06 AM
  #491
WLAURENT's Avatar
Originally Posted by GRUNTS2K,Mar 12 2008, 09:15 AM
Whats that?
An overpun blower is what I am planning to do. Eaton only rates the MP62 to 17k or so rpm. I will be running mine at 18.5k rpm once I get my new pulley installed. There are some race guys that are spinning it at 20-22k - but they change the SC oil every 10k miles (standard is 30k to 50k depending on how hard you run it).
Not sure I will see 400 WHP - but I should see 350 or so plus a significant bit more TQ through the entire rpm range.
Old Mar 12, 2008 | 12:46 PM
  #492
derek14's Avatar
As these guys stated, is there an estimated date of release? Im lost in anticipation
Old Mar 12, 2008 | 05:11 PM
  #493
y4ngel's Avatar
HMMMMMM, so tempting.
I'm debating between this kit. And a used Comptech SC w/ AC and 4.56 gears with comptech reinforced diff.
Since I most likely have to upgrade diff anyway, the CTSC route is cheaper. Someone convince me otherwise?
Old Mar 12, 2008 | 05:20 PM
  #494
camuman's Avatar
[QUOTE=y4ngel,Mar 12 2008, 08:11 PM]HMMMMMM, so tempting.
Old Mar 12, 2008 | 05:30 PM
  #495
y4ngel's Avatar
The CTSC pulls similar HP numbers up top, the 4.56 gears will make up for some of the torque difference down low. (at least the way it feels, not actual numbers).
Just throwing it out there
Old Mar 12, 2008 | 05:39 PM
  #496
UberDuper's Avatar
The CTCS and Vortech kits leave something to be desired when it comes to tuning.
I'm waiting on this or the kraftwerks you tune kit (and the money) in order to use an emanage ult + larger injectors.
UD.
Old Mar 12, 2008 | 05:50 PM
  #497
Spec_Ops2087's Avatar
regardless of the gears, this SC kit would pull on your car all day long
Old Mar 12, 2008 | 06:46 PM
  #498
neeman77's Avatar
And dont forget you can still add 4.56's to the BRP/SOT kit lol.
Old Mar 15, 2008 | 08:06 AM
  #499
derek14's Avatar
I have a CTSC Im giving up. Just throwing THAT out there
Can't wait for the SOT to replace it! Wooo!
Old Mar 15, 2008 | 08:09 AM
  #500
derek14's Avatar
those are staying in my rear. Should make for a very touchy throttle response
